iLogic rule to change save settings on the save tab in iProperties
JasonMayes
JasonMayes
This one is probably pretty easy but for the life of me I cant figure out how to select a radio button selection in iProperties with an iLogic rule. What is happening is when I drop a custom part in an assembly from CC the save view stays at the default setting and I would like to have an iLogic rule to run at the "before save" trigger to change this setting to ISO view. I can manipulate all to other iProperties but can't seem to figure out how to change that dang radio button selection. Any thoughts?
Jason
MechMachineMan
It's right there in the Programming Help Documentation.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-A23F3003-468E-4A3E-90D3-C8F0B21E2BB1
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Curtis_Waguespack
Hi JasonMayes,
There is an example here as well:
https://forums.autodesk.com/t5/inventor-forum/i-want-to-change-thumbnail-color/m-p/6788487#M626185
I hope this helps.
Curtis
