ilogic Rule in part runs from assembly.
m_rubach
m_rubach
Hi, at the begining I would like to say that I am beginer in iLogic.
I have written ilogic rules which changes color surfaces depends which value is in custom properties.
i added attribute name for surface which i want to change.
The trigger of rule is set after any change iProperties in part.
When I am in the part, the rule works well, but when I change the custom property from the assembly level, which triggers rules in the part, that rule doesn't work.
I suppose that issues with
ThisApplication.ActiveEditDocument
I get an error (unfortunately not english language):
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveEditDocument
Dim oCompDef As ComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
Dim oFaces As Faces
Dim oFace As Face
Dim oSurfBodies As SurfaceBodies
Dim oSurfBody As SurfaceBody
Dim oStyle As RenderStyle
	oStyle = oPartDoc.RenderStyles.Item("Green")
	 oSurfBodies = oCompDef.SurfaceBodies
oFaces = oSurfBodies.Item(1).Faces
For Each oSurfBody In oSurfBodies
oFaces = oSurfBody.Faces
	For Each oFace In oFaces
		For i = 1 To 2
			Try
			If oFace.AttributeSets.Item(i).Item(1).Value = "Long1" Then
				If iProperties.Value("Custom", "Long1") = "1" Or iProperties.Value("Custom", "Long1") = "2" Then
				Call oFace.SetRenderStyle(kOverrideRenderStyle, oStyle)
				Else
				Call oFace.SetRenderStyle(kPartRenderStyle)
				End If
			End If
			If oFace.AttributeSets.Item(i).Item(1).Value = "Long2" Then
				If iProperties.Value("Custom", "Long2") = "1" Or iProperties.Value("Custom", "Long2") = "2" Then
				Else
				End If
			End If
			If oFace.AttributeSets.Item(i).Item(1).Value = "Short1" Then
				If iProperties.Value("Custom", "Short1") = "1" Or iProperties.Value("Custom", "Short1") = "2" Then
				Else
				End If
			End If
			If oFace.AttributeSets.Item(i).Item(1).Value = "Skort2" Then
				If iProperties.Value("Custom", "Short2") = "1" Or iProperties.Value("Custom", "Short2") = "2" Then
				Else
				End If
			End If
			Catch
			End Try
		Next
	Next
Next
WCrihfield
Hi @m_rubach.  Any time an iLogic rule may get triggered to run while the Document it is intended to be working on may not be the 'active' document, that rule should not be trying to get the 'active' document.  I think in this case, you could just replace:
...with this:
oPartDoc = ThisDoc.Document
...to fix that initial error/problem.  However, I also see other issues in that code.  Namely the use of very outdated object types and methods (RenderStyles).  See the following online help page on this topic:
Consistent Materials (Materials and Appearances)
Try using the following properties & methods instead:
PartDocument.ActiveAppearance
PartDocument.ActiveMaterial
PartDocument.AppearanceAssets
PartDocument.Assets
PartDocument.MaterialAssets
Application.ActiveAppearanceLibrary
Application.ActiveMaterialLibrary
Application.AssetLibraries
AssetLibraries
AssetLibrary
Asset
MaterialAsset
Face.Appearance
Face.AppearanceSourceType
Wesley Crihfield
(Not an Autodesk Employee)
m_rubach
@WCrihfield Thanks! Works well.
As you suggested, I change method to change appearance.
Dim oFaces As Faces
Dim oFace As Face
Dim oSurfBodies As SurfaceBodies = oCompDef.SurfaceBodies
Dim localAsset As Asset = oPartDoc.Assets.Item("Green")
Dim localAssetDefault As Asset = oPartDoc.Assets.Item("White")
		For i = 1 To 2
			Try
				oFace.Appearance = localAsset
				Else
				oFace.Appearance = localAssetDefault
				End If
			End If
				Else
				End If
			End If
				Else
				End If
			End If
			If oFace.AttributeSets.Item(i).Item(1).Value = "Short2" Then
				Else
				End If
			End If
			Catch
			End Try
		Next
	Next
Next
