How do i install Add in on other computers
217694G9MEZ
217694G9MEZ
i currently made a AddIn in Visual Studio on my computer for my collagues at work. I want to add the AddIn to their computers. How do i do it? We are using Vault, so it would be great if all the workstations had the AddIn.
Thanks in advance.
Ralf_Krieg
Hello
You can simply copy the Addin dll and the .addin file to all other computers. You can create a setup project which encapsulates the copying in a setup process.
Read this article --> https://modthemachine.typepad.com/my_weblog/2012/02/migrate-net-add-ins-to-registry-free.html
Most interesting point is chapter 4.
R. Krieg
RKW Solutions
www.rkw-solutions.com
pball
The most simple way would be to copy the .addin and .dll files to a valid addin folder on everyone's computer manually. The next step would be to create an installer that would do that with little effort. I personally have a batch script that uses 7zip to create a self extracting zip file. If you have winrar I remember that being easier to use. There are plenty of methods out there.
I also personally have my addin install in the below folder path.
%appdata%\Autodesk\ApplicationPlugins
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
217694G9MEZ
Thank you both, it helped a lot.
suneelkumarYX7P2
Hii @pball
Thanks for the insights along with the .dll and .addin file we need to copy the standard 3dmodels and external ilogic rules but every time copying all this files in clients machine plugins folder c drive is difficult. Is possible to create an installer with all this files ie .dll, .addin, 3Dmodels and external rules or any other way to deploy in client machine?
pball
Yes you can create an installer. There should be plenty of guides if you search for making an installer or you could use a self extracting archive.
