iAssembly iLogic to overwrite weight
fwerth
fwerth
Hello everyone,
I am having a problem applying an ilogic rule in an assembly. The assembly contains several iAssembly variants. The tables of the inserted iAssemblies also contain a “Mass” column, which specifies the weight of the respective variant. The ilogic rule is supposed to search for the weight of each variant in the assembly from its table, add them up, and insert them into the physical iProperties.
This should work, but unfortunately it does not recognize the “ActiveTableRow” command to find the column of the inserted variant in its table.
Does anyone have any ideas for improvement?
Best Regards
Fabio
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim totalWeight As Double = 0
For Each oOcc As ComponentOccurrence In oAsmDoc.ComponentDefinition.Occurrences
    Try
        Dim occDoc As Document = oOcc.Definition.Document
        If occDoc.DocumentType = kPartDocumentObject Or occDoc.DocumentType = kAssemblyDocumentObject Then
            If occDoc.ComponentDefinition.IsiAssemblyMember Then
                Dim member As iAssemblyMember = occDoc.ComponentDefinition.iAssemblyMember
                ' Die aktuell in der Baugruppe verwendete Variante holen
                Dim row As iAssemblyTableRow = member.ActiveTableRow
                If Not row Is Nothing Then
                    Dim variantWeight As Double = CDbl(row("Masse").Value)
                    totalWeight += variantWeight
    Catch ex As Exception
    End Try
Next
' Physikalische Masse überschreiben
oAsmDoc.ComponentDefinition.MassProperties.Mass = totalWeight
WCrihfield
Hi @fwerth.  You can use the ComponentOccurrence.IsiAssemblyMember property directly from the ComponentOccurrence object first.  Then, if that is true, you can dig down into the ComponentOccurrence.Definition , which will be the AssemblyComponentDefinition object, then use its AssemblyComponentDefinition.iAssemblyMember property to get the actual iAssemblyMember object.  Then, use its iAssemblyMember.Row property, instead of the "ActiveTableRow" that you are trying to use in your example.  From the iAssemblyTableRow object that you get from the 'Row' property, you can use its iAssemblyTableRow.Item property to access the iAssemblyTableCell holding the 'Mass' value.  Be aware though, if any of your components are suppressed, then your line of code that attempts to access the ComponentOccurrence.Definition property will throw an error, because it can not access the definition of a suppressed component.
Wesley Crihfield
(Not an Autodesk Employee)
fwerth
Hey @WCrihfield
Thank you very much! You have solved my problem!
I have now expanded the code so that it also adds up the weights of components that are not iAssemblies.
    Try
        ' Prüfen, ob Occurrence ein iAssembly-Mitglied ist
        If oOcc.IsiAssemblyMember Then
            ' iAssemblyMember holen
            Dim member As iAssemblyMember = oOcc.Definition.iAssemblyMember
            ' Aktuelle Zeile
            Dim row As iAssemblyTableRow = member.Row
                ' Zelle "Masse" auslesen
                Dim cell As iAssemblyTableCell = row.Item("Masse")
                Dim variantWeight As Double = CDbl(cell.Value)
			 Else
            ' Normales Teil / Baugruppe → Inventor-Masse
            Dim occMass As Double = oOcc.MassProperties.Mass
            totalWeight += occMass
        ' suppressed Occurrences oder fehlende Spalten überspringen
    End Try
Next
Dim massProps As MassProperties
massProps = oAsmDoc.ComponentDefinition.MassProperties
' In iProperties schreiben
iProperties.Value("Custom", "Masse") = totalWeight
MessageBox.Show("Masse = " & totalWeight & " kg", "iLogic Info")
