11:28 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i'm new to ilogic but have been trying to write a couple of rules to improve productivity to create custom BOMs based on Excel template. I have been piecing together code and so it's working okay. I am however stuck on extracting bend counts of sheetmetal parts in my assembly. Whilst there are snippets to get number of bends, I cant find a snippet to get this info on parts from within an assembly. Below is a modified version from Clint Browns code that I've been trying to adapt for my purposes. o7 is my new variable to hold bend counts.
Can anyone help me with this ?
' Acknowledgement to Clint Brown for the original ilogic snippet Dim doc = ThisDoc.Document If doc.DocumentType = kAssemblyDocumentObject Then Else Return End If 'Create Text file BOM of current open assembly oWrite = IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt") oWrite.WriteLine("----------------------------------- Bill of Materials ----------------------------------------") oWrite.WriteLine("") oWrite.Close() SheetMetalCheckGUID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" ' This is the Sheet Metal unique identifier 'Iterate through the Assembly to find Sheet Metal parts Dim oAssyDoc As AssemblyDocument Dim oCompOccEnum As ComponentOccurrencesEnumerator Dim oCompOcc As ComponentOccurrence oAssyDoc = ThisApplication.ActiveDocument oCompOccEnum = oAssyDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oAssyDoc.ComponentDefinition) For Each oCompOcc In oCompOccEnum If oCompOcc.Definition.Document.SubType = SheetMetalCheckGUID Then 'Check for Sheet Metal parts Try 'Set up properties To Write To the BOM o1 = oCompOcc.Name & " : " & iProperties.MaterialOfComponent(oCompOcc.Name) o2 = " -- Part Number: " & iProperties.Value(oCompOcc.Name, "Project", "Part Number") o3 = " -- Mass: " & iProperties.MassOfComponent(oCompOcc.Name) o4 = " -- Material: " & iProperties.MaterialOfComponent(oCompOcc.Name) o5 = " -- Thickness: " & Parameter(oCompOcc.Name, "Thickness") o6 = "--" & iProperties.MaterialOfComponent(oCompOcc.Name) 'Dim o7 As SheetMetalComponentDefinition 'o7 = "-- Bends in (if sheetmetal) part" & oCompOcc.FlatPattern.FlatBendResults 'MessageBox.Show(oAssyDoc.Bends.Count) oInfo = o1 & o2 & o3 & o4 & o5 & o7 Dim oAppend As System.IO.StreamWriter 'Update Txt BoM oAppend = IO.File.AppendText(ThisDoc.PathAndFileName(False) & ".txt") oAppend.WriteLine(oInfo) oAppend.Flush() oAppend.Close() Catch MessageBox.Show("Oh Snap!", "@ClintBrown3D") End Try End If Next ThisApplication.StatusBarText = "Unoffical Inventor - Sheet Metal BoM Export Successful" i = MessageBox.Show("Would you like to see the Parts List?", "Unofficial Inventor", MessageBoxButtons.YesNo) If i = vbYes Then ThisDoc.Launch(ThisDoc.PathAndFileName(False) & ".txt") Else Return End If
