Why cannot get SelectionSet in DrawingSheet
1354448288
1354448288
I used the following codes to get a SelectionSet from a drawing sheet, but I cannot get anything.  The Visual Studio send tips:  cannot make the System._ComObject to Inventor.SelectionSet.
Here are my code:
SelectSet selectSet = null;
            if (drawingDocument.SelectSet.Count == 0)
                Console.WriteLine("Select a drawing view");
                //selectSet = inventorApp.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view");
                selectSet = inventorApp.CommandManager.Pick(SelectionFilterEnum.kDrawingSheetFilter, "Select drawing sheet!");
            else
                selectSet = drawingDocument.SelectSet;
After running the codes, I choosed the red line, (of course, the other lines are banned to choose), and the Visual Studio send the message : cannot make the System._ComObject to Inventor.SelectionSet.
I am very confused about it. How should I get the SelectionSet?
bradeneuropeArthur
This will work:
Public Sub main()
Dim a As Object
Set a = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingSheetFilter, "Select drawing sheet!")
MsgBox a.Name
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
and this works too:
Public Sub main()
Dim a As SelectSet
Set a = ThisApplication.ActiveDocument.SelectSet
 a.Select(ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingSheetFilter, "Select drawing sheet!"))
MsgBox a.Item(1).Name
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
