UCS to UCS Constraint SUb-Assembly to Part
In the Assembly file, I wanted to make a constraint set (UcsToUcs) from a subassembly ucs to a part ucs.
When I run the code it says "Public member 'Constraints' on type 'PartComponentDefinition' not found."
Please see the snapshot and sample files in version2020.
Thank you.
Dim oSubAsm As AssemblyDocument = ThisAssembly.Document
Dim wfUCSs As UserCoordinateSystems
'Create a list for skUCS
For Each oRefDoc As Document In oSubAsm.ReferencedDocuments
	'Get the wireframe
	If oRefDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject AndAlso oRefDoc.DisplayName.Contains("wireframe") Then
		Dim wfDoc As PartDocument = oRefDoc
		wfUCSs = wfDoc.ComponentDefinition.UserCoordinateSystems
Next
	 If oRefDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject
		Dim oAsmDoc As AssemblyDocument = oRefDoc
			For Each oPartDoc As PartDocument In oAsmDoc.ReferencedDocuments
					For Each wfUCS As UserCoordinateSystem In wfUCSs
						If oPartDoc.DisplayName.Contains(wfUCS.Name) Then
							MsgBox("Yes")
							Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
							Dim oUCS As UserCoordinateSystem = oCompDef.UserCoordinateSystems.Item("UCS_Origin")
							Dim oMate As FlushConstraint
							'Public member 'Constraints' on type 'PartComponentDefinition' not found
                                                        'Maybe because the parts are inside the sub-assembly
oMate = oCompDef.Constraints.AddFlushConstraint(oUCS, wfUCS, 0) End If Next Next End If Next
So in the Sub-Assemblies, I created a a UCS called "UCS_Origin". Those ucs will constrained with the wireframe ucs.
I use the ilogic's default
Constraints.AddUcsToUcs("UcsToUcs1", "Part1:1", "UCS1", "Part2:1", "UCS2",
                            xOffset := 0, yOffset := 0, zOffset := 0)
 The problem is it only worked for the last item. During iteration, it sort of created only  temporary constraint in the  other component.
This is the part where I need help as Im not sure what is the problem.
I was thinking to try to make the "AddUcsToUcs" rule as sub routin but I really dont know how to do that.
Please the video and code
below.
	'Get the wireframe
		wfDoc = oRefDoc
		'MsgBox(wfDoc.DisplayName)
Next
MsgBox(wfUCS.Name)
	'Create a list for asmUCS
			Dim oCompDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
				For Each oUCS As UserCoordinateSystem In oCompDef.UserCoordinateSystems
					If oUCS.Name.Contains("Origin") Then
						'MsgBox(oUCS.Name)
								'MsgBox(wfUCS.Name)
								Dim i As Integer = 1
								Dim oMateName As String = "UcsToUcs_" & i
								Dim oComp1 As String
								oComp1 = oAsmDoc.DisplayName.Split(".").First & ":1"
								'MsgBox(oComp1)
								Dim oComp2 As String
								oComp2 = wfDoc.DisplayName.Split(".").First & ":1"
								'MsgBox(oComp2)
								Constraints.AddUcsToUcs(oMateName, oComp1, oUCS.Name, oComp2, wfUCS.Name,
								i = i + 1
						Next
				Next
	Next
Next
