iLogic Excel Multivalue parameter for Find same value
kfc10
kfc10
Hi, does anyone have an idea?
Is something like this possible with iLogic? Files in the attachment.
I created the code below and I don't know how to proceed.
location = "myfile.xlsx"
sheet1 = "Sheet1"
numberrow = ""
Try
	p1 = "dia"
	m1 = Parameter.Param(p1)
Catch
	'Creating a parameter
	op1 = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters.AddbyExpression(p1, 10, "mm")
End Try
Try
	p2 = "length"
	m2 = Parameter.Param(p2)
Catch
	op2 = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters.AddbyExpression(p2, 100, "mm")
End Try
'Creates a list of materials, draws from the list created in the Excel table LIST
MultiValue.List(p1) = GoExcel.CellValues(location, sheet1, "B2", numberrow)
i = GoExcel.FindRow(location, sheet1, "dia", "=", Parameter("dia"))
Parameter("length") = GoExcel.CellValue(location, sheet1, "C" & i)
dutt.thakar
@kfc10
I am not having Inventor 2022, so can not open your file, Maybe you can change some things as stated below in your code and see if that works.
location = "myfile.xlsx" ' Please add the file name with full file path here and not only the file name
sheet1 = "Sheet1"
numberrow = ""
Try
	p1 = "dia"
Catch
End Try
Try
	p2 = "length"
Catch
End Try
Parameter("length") = GoExcel.CurrentRowValue("length")
  If you can post the file in Inventor 2021 version, I would be able to look at the behaviour as well in Inventor.
Hope this will help you.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
kfc10
Hello, we did not understand. I guess I explain it wrong, sorry. I'll try to explain better. See picture.
dutt.thakar
@kfc10
Ok, I think I did not understand earlier, what you are trying to achieve but these snapshots had made it quite clear.
Try the below code. Keep in mind one thing, it assumes that, the diameter is always in the increment of 10mm,(i.e. 10, 20,30, etc.), and based on that it tries to find the right cell address and then add it to the multi-value list for length.
sheet1 = "Sheet1"
numberrow = ""
Try
	p1 = "dia"
Catch
End Try
Try
	p2 = "length"
Catch
End Try
i = GoExcel.FindRow(location, sheet1, "dia", "=", dia)
j = GoExcel.FindRow(location, sheet1, "dia", "=", dia + 10)
MultiValue.SetValueOptions(True, DefaultIndex := 0)
MultiValue.List(p2) = GoExcel.CellValues(location,sheet1,"C" & i,"C" & j-1)
RuleParametersOutput()
InventorVb.DocumentUpdate
Dutt Thakar
LinkedIn
kfc10
Hi @dutt.thakar
Thank you very much.
That's incredible. I thought that was not possible.
