Assembly instance property API reference Inventor 2022
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
How to change edit the "Assembly Instance Properties" of child files via the API?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Found:
Public Sub main()
Dim a As Inventor.Application
Set a = ThisApplication
Dim b As AssemblyDocument
Set b = a.ActiveDocument
Dim c As AssemblyComponentDefinition
Set c = b.ComponentDefinition
Dim occ As ComponentOccurrence
Set occ = c.Occurrences.Item(1)
MsgBox occ.OccurrencePropertySets.Item(1).Item(1).Name
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
nmunro
Your code will work if the user has already added an Instance property to the first occurrence in the assembly. In a more general application, you should add another step to ensure the occurrence has a valid Instance property set to work with. The following code works on a newly created assembly where no occurrences have had Instance Properties added via the Inventor UI.
Public Sub main()
' ensure the default occurrence property set is enabled
' this property set has the same internal name (GUID)
'   as the custom property set for a document
occ.OccurrencePropertySetsEnabled = True
' get the property set and add a property
Dim instancePropSet As PropertySet
Set instancePropSet = occ.OccurrencePropertySets(1)
Dim instanceProp As Property
Set instanceProp = instancePropSet.Add("World", "HelloProperty")
'show instance prop data
MsgBox instanceProp.Name & ": " & instanceProp.Value
End Sub
https://c3mcad.com
CattabianiI
Just to avoid headaches if you get your hands dirty on the subject, at the moment there is this known bug that should be fixed in the next release:
INVGEN-50622: OccurrencePropertySetsEnabled = True throws an exception if the assembly file is readonly.
beta program link
bradeneuropeArthur
Have you already reported it to the development team?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
CattabianiI
I reported it in the beta program forum (that's the small link above) and they gave me that issue ID.
