iLogic Ribbon doesn't display external rules until reload
william
william
Curious as to whether anyone has seen this behavior before and potential cause.
Seems to occur randomly.
WCrihfield
Hi @william.  That certainly is odd behavior.  Do you have all your 'iLogic Configuration' settings set-up properly?
Tools tab > Options panel > iLogic Configuration (opens 'Advanced iLogic Configuration' dialog)
Make sure the 'External Rule Directories' section is filled in, and make sure the 'Default Extension for External Rule Files' setting is set the way you want it.  Then, just for good measure, it's usually a good idea to export these settings to an XML file, using the buttons provided along the bottom.
Wesley Crihfield
(Not an Autodesk Employee)
william
yes I checked all the mentioned options.
It was happening on all files in the Inventor session yesterday, opening from vault, create new part, etc.
Started Inventor this morning and no issues. Pretty hard to troubleshoot with not much info. I just wondered if anyone else had this issue and knew of a cause/solution.
bradeneuropeArthur
I see sometimes the same behaviour.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
