Inventor 2023, ilogic Rules and Forms on Ribbon.
BDCollett
Advisor Advisor
Message 1 of 14
BDCollett
Great feature.
Are you able to apply a custom icon to the rules? They don't seem to copy the icon from the list.
Replies (13)
Message 2 of 14
pcrawley
Good question Ben.  It doesn't look like there's anything other than the default scroll/script icon.  I hope someone here has a better solution.
I use the "Button Constructor" app' - see https://clintbrown.co.uk/2020/11/28/run-ilogic-rules-from-the-ribbon/ - which works a treat in Inventor 2022.  Haven't tried it in 2023 yet.
Peter
Message 3 of 14
mat_hijs
I believe you can customize the icon by placing png images in the same folder as your external rule or global form. Try this out.
For a rule named "RuleX":
For a form named "FormX":
For the small/large I believe they should be either 16x16 and 32x32, but I'm not 100% sure about that.
Message 4 of 14
BDCollett
I only had the name matching not the extra text. On testing again when it's set to LARGE the icon does work. I have a 16x16 PNG.
Message 5 of 14
JelteDeJong
I have updated the ButtonConstructor for inventor 2023. It is available in the AppStore. More information can be found on my site: http://www.hjalte.nl/
Jelte de Jong
Blog: hjalte.nl - github.com
Message 6 of 14
BDCollett
Is it possible to add Forms with this as well?
Message 7 of 14
James_Willo
Hi, to add a button to the ribbon:
  • Right click a ribbon Customize User Commands
  • Filter rules/forms in the drop down
  • Ensure the correct tab is listed
  • Double click a rule to add
  • Add text or make large
To create a custom icon use:
png format
16x16px or 32x32px
Must be put in the same folder as the Rule is stored
File name:
Example: “Push Parameters.light.large.png”
If it doesn't update immediately, restart Inventor.
James W
Inventor UX Designer
Message 8 of 14
Maxim-CADman77
@mat_hijs
I wonder where you get this info from?
Is it presented somewhere in official documentation or other public source (maybe there are other non-obvious yet worth of attention things described there)?
Please vote for Inventor-Idea Text Search within Option Names
Message 9 of 14
mat_hijs
I read about this in some what's new PDF that I believe was sent to the members of the feedback community. Other than that I haven't been able to find anything about it on the Inventor help.
Message 10 of 14
James_Willo
I believe the PDF you are talking about is the one I created.
I've just had a look now and I don't know if there is a help file anywhere describing how to do this.
James W
Message 11 of 14
Ethibaudeau
To add on to this, for users of dark mode:
From my testing it appears that Inventor will turn any pure white (255, 255, 255) pixels to transparent. If this is blanking out intended white areas of your icon, edit them to use just slightly off white (254, 254, 254) and those pixel will appear white / will not be made transparent by Inventor.
Message 12 of 14
Quoc_Kiet
I can't not get icon to Global Forms.
Message 13 of 14
WCrihfield
Just dropping a link in here to one of my recent forum responses under another topic that I think will be helpful for some folks that have found this topic.
https://forums.autodesk.com/t5/inventor-programming-ilogic/save-thumbnail-as-image-file/m-p/13014204...
It has a text file attachment, and within that text file is code for an iLogic rule that can be used to capture both the large and small (or standard) icons of existing buttons that are currently defined within Inventor, and saves them out as png files.  Those files are already the correct sizes, correct file types, and have the correct file names for use as button icons that can be used for ButtonDefinitions for other iLogic rules.
But for convenience, I will attach that file here also.  But within that other (linked to) conversation are some interesting, and maybe useful alternative codes (and Links) showing how to get other native Inventor images (IPictureDisp) to external files.  There have been multiple variations of codes for these types of purposes floating around for years, but many of the older ones are getting very outdated, and may not even work anymore.  There are apparently multiple internal variations of these IPictureDisp image data types that Inventor uses internally for various purposes.  One variation is used for the Document.Thumbnail (which is an IPictureDisp), and another variation is used for the button icons (ButtonDefinition.LargeIcon & ButtonDefinition.StandardIcon).  These two different variations, one designed for Bitmap use, the other for Icon use, require slightly different processes to convert before saving as an external png file.
There is a similar code within that other conversation for saving the document thumbnail images out too, if interested.
Wesley Crihfield
(Not an Autodesk Employee)
Message 14 of 14
kresh.bell
Hi @JelteDeJong
is it possible to place the RuleButtonSettings.xml file on the share location? I would like more users to use the same settings.
