ilogic relativ Update view
I have a drawing with ilogic rule. My rule suppresses view etc. I change any parametr in model and all views update, but my section-line in parent view doesnt update. Line of section is fully constrained in sketch, but my reference edge doesnt update. Of course I can select parent section and update view manually but I want to do it by ilogic. Have anybody this problem and solution? Help me, please.
kelly.young has embedded your image for clarity.
bradeneuropeArthur
Are the views cropped?
Are the views broken break views?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
The views arent cropped.
The views arent break views.
Its normal full view, which includes a sketch with the section line. I attach a describing picture for clarification.
marcin_otręba
green corners of the view means that it is not precise... RMB on it end then click on make view precise or something... it can be accomplished by code as well.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
