iLogic Print Code - How to set paper size?
Jason.Rugg
Message 1 of 8
Jason.Rugg
I have the following iLogic code for printing, it works great other than I can not get it to print Ledger/11x17. No matter how I try setting the paper size it refuses to print anything except Letter/8.5x11. Anyone have any other suggestions on how to set paper size?
'Print Setup
Dim oDrgDoc As DrawingDocument
oDrgDoc = ThisApplication.ActiveDocument
' Set reference to drawing print manager' DrawingPrintManager has more options than PrintManager' as it's specific to drawing document
Dim oDrgPrintMgr As DrawingPrintManager
oDrgPrintMgr = oDrgDoc.PrintManager
' Set the printer name' comment this line to use default printer or assign another one
'oDrgPrintMgr.Printer = "\\kcidc2012\EngineeringSharp_Ledger"
'oDrgPrintMgr.Printer = "EngineeringSharp_Ledger"
oDrgPrintMgr.Printer = "\\kcidc2012.kciinc.net\EngineeringSharp_Ledger"
'Set the paper size , scale and orientation
oDrgPrintMgr.ScaleMode = kCustomScale
oDrgPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
'oDrgPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeLedger
oDrgPrintMgr.PaperSize = 14338
oDrgPrintMgr.PrintRange = kPrintCurrentSheet
oDrgPrintMgr.Orientation = kLandscapeOrientation
oDrgPrintMgr.PaperSource = 2
oDrgPrintMgr.AllColorsAsBlack = True
oDrgPrintMgr.SubmitPrint
Replies (7)
Message 2 of 8
bradeneuropeArthur
You need to change the printersetting themselves.
go to your paper setting of the printer and change it there.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
Jason.Rugg
@bradeneuropeArthur Thanks for the suggestion but I have tried that.
Message 4 of 8
Jason.Rugg
@bradeneuropeArthur I am just removing the paper size callouts since the printer defaults to 11x17. One other issue I am having is black and white versus color. I want prints to be black and white, is there a different way of calling out that option in my code? The way it is it prints color.
Message 5 of 8
bradeneuropeArthur
first change this:
oDrgPrintMgr.PaperSize = kPaperSizeLetter ' or 14353
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 8
bradeneuropeArthur
regarding the color:
Color print is as follows:
oDrgPrintMgr.AllColorsAsBlack = False
Black and white is as follows:
The code works fine with me....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
Jason.Rugg
This worked or even just completely commenting out paper size altogether worked since default is 11 x 17.
oDrgPrintMgr.PaperSize = PaperSizeLedger
Just need to figure out the color issue. Using: "oDrgPrintMgr.AllColorsAsBlack = True" still prints in color.
Message 8 of 8
bradeneuropeArthur
the following works fine here...
Public Sub Main()
'Print Setup
oDrgPrintMgr.PaperSize = kPaperSizeLedger 'or 14341' kPaperSizeLetter
MsgBox (oDrgPrintMgr.PaperSize)
End Sub
what version of inventor are you using?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
