iLogic preset options for for PDF export in filedialog
I have an ilogic for exporting pdfs to the correct folder with the correct file name. Before saving with the PDF translator, a FileDialog opens so that I can check the file name and set the options. The issue I am having is, the first time I use the rule after opening inventor, the FileDialog sets the print range to 'Sheet in range: From 5 to 6". After I set it to all sheets it stays but if I close and reopen inventor it goes back to sheets in range.
Is there a way to set the FileDialog options so it defaults to print all sheets before the rule shows the dialog box?
