iLogic preset options for for PDF export in filedialog
NickSycamore
NickSycamore
I have an ilogic for exporting pdfs to the correct folder with the correct file name.  Before saving with the PDF translator,  a FileDialog opens so that I can check the file name and set the options.  The issue I am having is, the first time I use the rule after opening inventor, the FileDialog sets the print range to 'Sheet in range: From 5 to 6". After I set it to all sheets it stays but if I close and reopen inventor it goes back to sheets in range.
Is there a way to set the FileDialog  options so it defaults to print all sheets before the rule shows the dialog box?
Cris_Davis
Try this,
PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
End If
NickSycamore
Thanks for the response Cris.  I added the if statement and it didn't help.  I tried moving it to before the filedialog to see if I could set the options but no luck.
Here is what I have. I works but I don't know how to set the options for the filedialog.  I know I could set the options after the filedialog, before saving the file but I would like to be able to change the options if I want using the filedialog. I just want it to default to print all sheets.
Dim plotPath As String = "C:\"
Dim DefaultFileName As String = "test file.pdf"
Dim PDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
	Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
	Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	If PDFAddIn.HasSaveCopyAsOptions(odrawdoc, oContext, oOptions) Then
		oOptions.Value("Sheet_Range") = PrintRangeEnum.kPrintAllSheets
	End If
	'FILE DIALOG
	Dim oFileDialog As Inventor.FileDialog = Nothing
	ThisApplication.CreateFileDialog(oFileDialog)
	oFileDialog.Filter = "PDF (*.pdf)|*.pdf"
	oFileDialog.InitialDirectory = plotPath
	oFileDialog.FileName = DefaultFileName
	oFileDialog.DialogTitle = "Export PDF"
	oFileDialog.OptionsEnabled = True
	oFileDialog.ShowSave()
	If (String.IsNullOrEmpty(oFileDialog.FileName)) Then
		MsgBox("No name given")
		Exit Sub
	End If
	'PDF TRANSLATOR
	oDataMedium.FileName = oFileDialog.FileName
	PDFAddIn.SaveCopyAs(odrawdoc, oContext, oFileDialog.OptionValues, oDataMedium)
jwingateRJECD
Try this, I took the file dialogue call that you were using and put it into the pdf export rule I use and was successful in getting the pdf to export all sheets. Hope this helps.
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 1200
'get PDF target folder path
oFolder = oPath
ThisApplication.ActiveView.Update()
'FILE DIALOG
		Exit Sub
	End If
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
oPDFAddIn.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oDataMedium)'For PDF's
NickSycamore
@jwingateRJECD  This looks like it works because its using the options that are defined by "oOptions" not "oFileDialog.OptionValues".  I would like to have the ability to use the file dialog options so I can print just the current sheet if I have to.  The problem is when I run the rule the default option for sheet range is always set to "Sheets in Range" in the file dialog options.
I found a work around for setting options with the translator.  I can have the options dialog show after the file dialog so I can confirm or change the settings.
'change from true to false
oFileDialog
.OptionsEnabled = false
'Then add this after you show the file dialog.
PDFAddIn.ShowSaveCopyAsOptions(odrawdoc,oContext,oOptions)
NickSycamore
Another thing I just found is that if you use the export pdf in the ribbon or the "AppFileExportPDFCmd" command, Inventor will remember those values as the default options.  I guess Inventor doesn't remember those values when using the translator in iLogic.
