Import custom properties from excel sheet
kresh.bell
Message 1 of 10
kresh.bell
I have a great code to import custom properties from excel sheet, it works great.
Sometimes I need them only in the assembly, not in all parts. Is it possible to edit it to import data only in the assembly?
Sub Main
Dim fileDlg As Inventor.FileDialog = Nothing
	InventorVb.Application.CreateFileDialog(fileDlg)
	fileDlg.Filter = "Spredsheet Files (*.xls) (*.xlsx) (*.xlsm) (*.xlsb)|*.xls; *.xlsx; *.xlsm; *.xlsb"
	'Set open location using one of these 2 options below, "1)Hard coded" or "2)Project location":
	'fileDlg.InitialDirectory = "D:\INVENTOR DATA\PROJEKTI\"  'Hard Coded path:
	fileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
	'Show File Open Dialogue
	fileDlg.DialogTitle = "Browse for XLS File"
	fileDlg.ShowOpen()
	Dim xlFile As String  = fileDlg.FileName
	If xlFile = "" Then : Exit Sub: End If
	'Open Excel file.
	GoExcel.Open(xlFile, "Job Sheet")
	Dim doc As Document = ThisDoc.Document
	Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(doc, "Custom Properties Import") 'Make this a single transaction
	Dim filename As String  = Nothing
	processDocument(filename,xlFile)
	If doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		'Traverse all referenced documents.
		For Each refDoc As Document In doc.AllReferencedDocuments
			'Avoid readonly files like CC and Library.
			If refDoc.IsModifiable Then
				filename = IO.Path.GetFileName(refDoc.FullFileName)
		Next
	'Close Excel file.
	GoExcel.Close
	trans.End 'End the trasaction
	MessageBox.Show("Job Sheet Successfully Imported", "Job Sheet")
End Sub
Sub processDocument(filename As String, xlFile As String)
	'Read from Excel file
	iProperties.Value(filename,"Custom", "Referenced Spreadsheet File Name") = xlFile
	iProperties.Value(filename,"Custom", "AreaCode") = GoExcel.CellValue("H4")
	iProperties.Value(filename,"Custom", "AreaName") = GoExcel.CellValue("C4")
	iProperties.Value(filename,"Custom", "ComponentCode") = GoExcel.CellValue("H7")
	iProperties.Value(filename,"Custom", "ComponentName") = GoExcel.CellValue("C7")
	iProperties.Value(filename,"Custom", "Priority") = GoExcel.CellValue("P7")
	iProperties.Value(filename,"Custom", "D365WoNumber") = GoExcel.CellValue("H8")
	iProperties.Value(filename,"Custom", "DWGName") = GoExcel.CellValue("C6")
	iProperties.Value(filename,"Custom", "DWGRef") = GoExcel.CellValue("H6")
	iProperties.Value(filename,"Custom", "FSCReg") = GoExcel.CellValue("N20")
	iProperties.Value(filename,"Custom", "HealthSafetySheets") = GoExcel.CellValue("H19")
	iProperties.Value(filename,"Custom", "IssuedTo") = GoExcel.CellValue("P6")
	iProperties.Value(filename,"Custom", "ItemCode") = GoExcel.CellValue("H5")
	iProperties.Value(filename,"Custom", "ItemName") = GoExcel.CellValue("C5")
	iProperties.Value(filename,"Custom", "LoadList") = GoExcel.CellValue("C20")
	iProperties.Value(filename,"Custom", "ProjectCode") = GoExcel.CellValue("H3")
	iProperties.Value(filename,"Custom", "Project_Name") = GoExcel.CellValue("C3")
	iProperties.Value(filename,"Custom", "RefDrawing") = GoExcel.CellValue("C6")
	iProperties.Value(filename,"Custom", "TehnicalDataSheets") = GoExcel.CellValue("P19")
	iProperties.Value(filename,"Custom", "UnitQty1") = GoExcel.CellValue("A22")
	iProperties.Value(filename,"Custom", "UnitQty2") = GoExcel.CellValue("A23")
	iProperties.Value(filename,"Custom", "UnitQty3") = GoExcel.CellValue("A24")
	iProperties.Value(filename,"Custom", "UnitName1") = GoExcel.CellValue("B22")
	iProperties.Value(filename,"Custom", "UnitName2") = GoExcel.CellValue("B23")
	iProperties.Value(filename,"Custom", "UnitName3") = GoExcel.CellValue("B24")
	iProperties.Value(filename,"Custom", "UnitEmpty1") = GoExcel.CellValue("C22")
	iProperties.Value(filename,"Custom", "UnitEmpty2") = GoExcel.CellValue("C23")
	iProperties.Value(filename,"Custom", "UnitEmpty3") = GoExcel.CellValue("C24")
	iProperties.Value(filename,"Custom", "UnitDescription1") = GoExcel.CellValue("D22")
	iProperties.Value(filename,"Custom", "UnitDescription2") = GoExcel.CellValue("D23")
	iProperties.Value(filename,"Custom", "UnitDescription3") = GoExcel.CellValue("D24")
	iProperties.Value(filename,"Custom", "Designer") = GoExcel.CellValue("P5")
	iProperties.Value(filename,"Custom", "DateReq") = GoExcel.CellValue("P4")
	iProperties.Value(filename,"Custom", "Client") = GoExcel.CellValue("C9")
	iProperties.Value(filename,"Custom", "Disney01") = GoExcel.CellValue("R3")
	iProperties.Value(filename,"Custom", "Disney02") = GoExcel.CellValue("R4")
	iProperties.Value(filename,"Custom", "Disney03") = GoExcel.CellValue("R5")
	iProperties.Value(filename,"Custom", "Disney04") = GoExcel.CellValue("R6")
	iProperties.Value(filename,"Custom", "Disney05") = GoExcel.CellValue("R7")
	iProperties.Value(filename,"Custom", "Disney06") = GoExcel.CellValue("R8")
	iProperties.Value(filename,"Custom", "Disney07") = GoExcel.CellValue("R9")
End Sub
Replies (9)
Message 2 of 10
Ivan_Sinicyn
Do you want a dialog box at startup asking you to go through all files or just the current assembly?
Sub Main
    ' Display dialog box to choose import scope
    Dim importChoice As Integer
    importChoice = MessageBox.Show("Import data to all assembly components?" & vbCrLf & _
                                   "Yes - all components, No - current assembly only", _
                                   "Select Import Mode", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
    ' Define current document
    ' Check if document is an assembly
    If doc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        MessageBox.Show("This script is intended for assemblies only.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Exit Sub
    ' Create file dialog for selecting Excel file
    fileDlg.Filter = "Spreadsheet Files (*.xls;*.xlsx;*.xlsm;*.xlsb)|*.xls;*.xlsx;*.xlsm;*.xlsb"
    ' Set open location using one of these 2 options: "1) Hard coded" or "2) Project location"
    'fileDlg.InitialDirectory = "D:\INVENTOR DATA\PROJEKTI\"  ' Hard Coded path
    fileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath  ' Project location
    fileDlg.DialogTitle = "Select Excel File"
    fileDlg.ShowOpen()
    ' Check if a file was selected
    If String.IsNullOrEmpty(xlFile) Then Exit Sub
    ' Open Excel file
    ' Start transaction for changes
    ' Process current document (assembly)
    ProcessDocument(Nothing, xlFile)
    ' Process all referenced documents if "Yes" was selected
    If importChoice = vbYes Then
                Dim filename As String = IO.Path.GetFileName(refDoc.FullFileName)
                ProcessDocument(filename, xlFile)
        Next
    ' Close Excel file and end transaction
    GoExcel.Close
    trans.End
    ' Display success message based on import scope
    Dim scopeMsg As String = If(importChoice = vbYes, "all components", "current assembly only")
    MessageBox.Show("Data successfully imported to " & scopeMsg, "Import Complete", MessageBoxButtons.OK, MessageBoxIcon.Information)
End Sub
Sub ProcessDocument(filename As String, xlFile As String)
    ' Define mapping of Excel cells to custom property names
    Dim propertyMap As New Dictionary(Of String, String) From {
        {"Referenced Spreadsheet File Name", xlFile},  ' Special case: uses file path directly
        {"AreaCode", "H4"},
        {"AreaName", "C4"},
        {"ComponentCode", "H7"},
        {"ComponentName", "C7"},
        {"Priority", "P7"},
        {"D365WoNumber", "H8"},
        {"DWGName", "C6"},
        {"DWGRef", "H6"},
        {"FSCReg", "N20"},
        {"HealthSafetySheets", "H19"},
        {"IssuedTo", "P6"},
        {"ItemCode", "H5"},
        {"ItemName", "C5"},
        {"LoadList", "C20"},
        {"ProjectCode", "H3"},
        {"Project_Name", "C3"},
        {"RefDrawing", "C6"},
        {"TehnicalDataSheets", "P19"},
        {"UnitQty1", "A22"},
        {"UnitQty2", "A23"},
        {"UnitQty3", "A24"},
        {"UnitName1", "B22"},
        {"UnitName2", "B23"},
        {"UnitName3", "B24"},
        {"UnitEmpty1", "C22"},
        {"UnitEmpty2", "C23"},
        {"UnitEmpty3", "C24"},
        {"UnitDescription1", "D22"},
        {"UnitDescription2", "D23"},
        {"UnitDescription3", "D24"},
        {"Designer", "P5"},
        {"DateReq", "P4"},
        {"Client", "C9"},
        {"Disney01", "R3"},
        {"Disney02", "R4"},
        {"Disney03", "R5"},
        {"Disney04", "R6"},
        {"Disney05", "R7"},
        {"Disney06", "R8"},
        {"Disney07", "R9"}
    ' Write data from Excel to custom properties using the mapping
    With iProperties
        For Each kvp As KeyValuePair(Of String, String) In propertyMap
            If kvp.Key = "Referenced Spreadsheet File Name" Then
                .Value(filename, "Custom", kvp.Key) = kvp.Value
            Else
                .Value(filename, "Custom", kvp.Key) = GoExcel.CellValue(kvp.Value)
        Next
    End With
End Sub
INV 2025.3
Message 3 of 10
kresh.bell
no, without dialog box
Message 4 of 10
Ivan_Sinicyn
Sub Main
        Exit Sub
    fileDlg.ShowOpen()
    ' Open Excel file
    ' Process only the current assembly
    GoExcel.Close
    trans.End
    MessageBox.Show("Data successfully imported to current assembly", "Import Complete", MessageBoxButtons.OK, MessageBoxIcon.Information)
End Sub
        {"AreaCode", "H4"},
        {"AreaName", "C4"},
        {"Priority", "P7"},
        {"DWGName", "C6"},
        {"DWGRef", "H6"},
        {"FSCReg", "N20"},
        {"IssuedTo", "P6"},
        {"ItemCode", "H5"},
        {"ItemName", "C5"},
        {"Designer", "P5"},
        {"DateReq", "P4"},
        {"Client", "C9"},
        {"Disney01", "R3"},
        {"Disney02", "R4"},
        {"Disney03", "R5"},
        {"Disney04", "R6"},
        {"Disney05", "R7"},
        {"Disney06", "R8"},
        {"Disney07", "R9"}
    With iProperties
            Else
        Next
    End With
End Sub
INV 2025.3
Message 5 of 10
kresh.bell
@Ivan_Sinicyn , thanks, that's great
Message 6 of 10
kresh.bell
@Ivan_Sinicyn, I have one problem, it works for assembly but it stopped working in drawing. Is it possible for it to work also in drawing?
Message 7 of 10
Ivan_Sinicyn
The source code was an indiscriminate traversal of all referenced documents. Now it will be necessary to customize the filter if you want it to be applied to the drawing file. Do I understand correctly that the import should be performed only for the main assembly and its main drawing, which have identical file name?
INV 2025.3
Message 8 of 10
kresh.bell
Sometimes I need the data from the excel sheet to be applied only to the assembly in which I import it, not to the parts within that assembly. Your new code works great. I also need to use the same iLogic to import that data into the drawing. My first iLogic does that. Unfortunately, your new one does not. These data in the drawing are not connected to the assemblies in it, they are custom properties of that drawing
Message 9 of 10
Ivan_Sinicyn
@kresh.bell
If you want the code to work just with the active document, it is enough to remove the document type check:
        Exit Sub
Here is the final version:
Sub Main
    fileDlg.ShowOpen()
    ' Open Excel file
    GoExcel.Close
    trans.End
    MessageBox.Show("Data successfully imported", "Import Complete", MessageBoxButtons.OK, MessageBoxIcon.Information)
End Sub
        {"AreaCode", "H4"},
        {"AreaName", "C4"},
        {"Priority", "P7"},
        {"DWGName", "C6"},
        {"DWGRef", "H6"},
        {"FSCReg", "N20"},
        {"IssuedTo", "P6"},
        {"ItemCode", "H5"},
        {"ItemName", "C5"},
        {"Designer", "P5"},
        {"DateReq", "P4"},
        {"Client", "C9"},
        {"Disney01", "R3"},
        {"Disney02", "R4"},
        {"Disney03", "R5"},
        {"Disney04", "R6"},
        {"Disney05", "R7"},
        {"Disney06", "R8"},
        {"Disney07", "R9"}
    With iProperties
            Else
        Next
    End With
End Sub
INV 2025.3
Message 10 of 10
kresh.bell
@Ivan_Sinicyn perfect, thanks!!
