Difine New Property in BOM table
Fazlur_Rahaman
Fazlur_Rahaman
Does anyone know how to add a custom new Property in Part List Column Chooser in BOM?
I can't find any reference on how to create new one.
Thanks in Advance for any help.
JelteDeJong
This rule will add a column for the custom property Test.
Dim partsList As PartsList = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingPartsListFilter, "")
partsList.PartsListColumns.Add(PropertyTypeEnum.kCustomProperty, "", "Test")
Jelte de Jong
Blog: hjalte.nl - github.com
Fazlur_Rahaman
Thank you for the code.
I have another question: If i have two bom table on same sheet, is there a way to select one?
For example, i have two table on same page. One for assembly and one for shipped loose items. I want to sort the Ship loose items by the "ITEM" using the code above. Is there a way to do this?
Fazlur_Rahaman
I just noticed your code already does it using the
SelectionFilterEnum
thank you again for the help.
