Ilogic: Object reference not set to an instance of an object.
sreed
sreed
I have a form in my .idw that fills in my title block and I have a two rules that reach out to the model so that I can change the design state of the model from the .idw.  I can get this to work in a new drawing but when I open and existing drawing and input the form and rules I get errors when it comes to the design state of the model.
I get and error that the "Object reference not set to an instance of an object."  Can some one help me out?
I have attached a .idw and the two rules.
Steve
chandra.shekar.g
Autodesk Support
Autodesk Support
@sreed,
Try below changes in both iLogic code.
Get Reference assembly
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
oSheet = ActiveSheet.Sheet
oViews = oSheet.DrawingViews
If oViews.Count > 0 Then
	oView = oViews.Item(1)
	oModelName = oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
	Dim referDoc As Document
	referDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
	oAssemblyState = referDoc.PropertySets.Item("Design Tracking Properties").Item("Design Status").Value
	If oAssemblyState = 1 Then
		oAssemblyState = "WorkInProgress"
		Else If oAssemblyState = 2 Then
		oAssemblyState = "Pending"
		Else If oAssemblyState = 3 Then
		oAssemblyState = "Released"
	End If
	'MessageBox.Show(oAssemblyState, "Assembly State")
	Parameter("ModelDesignState") = oAssemblyState
End If
Push Design State
Dim oSheet As Sheet
	'MessageBox.Show(oModelName, "Assembly Name")
	oNewState = Parameter.Value("ModelDesignState")
	'MessageBox.Show(oNewState, "Model Design State")
	oAssemblyState = Parameter.Value("ModelDesignState")
	If oAssemblyState = "WorkInProgress" Then
		oAssemblyState = 1
		Else If oAssemblyState = "Pending" Then
		oAssemblyState = 2
		Else If oAssemblyState = "Released" Then
		oAssemblyState = 3
	End If
	referDoc.PropertySets.Item("Design Tracking Properties").Item("Design Status").Value = oAssemblyState
	'iProperties.Value(oModelName, "Status", "Design State") = oAssemblyState
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
sreed
Thank you for the help but I am getting an error now, I have attached the error.  Also I attached a pic of the event triggers I have set up.  Do you think the way I have that setup could be a problem?  The pic of the form show that the update model button will not high light.
Thank you,
Steve
chandra.shekar.g
Autodesk Support
Autodesk Support
@sreed,
Can you please sample drawing and model to test and video recording to demo on errors? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
sreed
I attached a pack and go of something simple I did for myself.   I am noticing I only receive these problems because the rules are external rules.  Any thoughts on this?  I would like to keep them external if possible.
Steve
chandra.shekar.g
Autodesk Support
Autodesk Support
@sreed,
Drawing document tested and found that Push Design State.txt rule is missing in external rule. After adding as external rule, deleted existing Update Model and recreated with Push Design State rule. Button is renamed to "Update model".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
