VB : Inventor API Exports with wrong scale
floyd.schramm
floyd.schramm
So I am working on a Project to export an .ipt as any CAD file with one key press. I got it working but whenever I export to an .stl the scale is wrong. Its exports like option "Units" is set to cm and not mm.
This is my implementation :
Imports InventorDim
ThisApplication
As Inventor.Application
In the Start Sub :
InitializeComponent()
Try
ThisApplication
= Marshal.GetActiveObject("Inventor.Application") Catch ex As Exception MsgBox(ex.ToString())
MsgBox
("Unable to get Inventor") End Try
This is the code is used to open the Export window :
Dim Commander As CommandManager
Commander = ThisApplication.CommandManager
Dim Controler As ControlDefinition Controler = Commander.ControlDefinitions.Item("AppFileExportCADFormatCmd") Call Controler.Execute()
But whenever the export window is opened via my program the export scale is wrong but when I open the window manually everything is fine. Is there something to add to the API call to get the desired scale?
Curtis_Waguespack
Hi @floyd.schramm
Welcome to the forum. Here is an iLogic STL export example that might help.
I hope this helps.
Curtis
oApp = ThisApplication
Dim oDoc As Document = ThisDoc.Document
Dim oSTL As TranslatorAddIn
oSTL = oApp.ApplicationAddIns.ItemById("{81CA7D27-2DBE-4058-8188-9136F85FC859}")
Dim oContext As TranslationContext
oContext = oApp.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oOptions As NameValueMap
oOptions = oApp.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = oApp.TransientObjects.CreateDataMedium
If oSTL.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
	oOptions.Value("OutputFileType") = 0 '0 = Binary , 1 = ASCII
	oOptions.Value("ExportUnits") = 5 'IN = 2, FT = 3, CM = 4, MM = 5
	oOptions.Value("Resolution") = 0  'HIGH = 0, MEDIUM = 1, LOW = 2
	oOptions.Value("ExportColor") = True
'Set the destination file name
oPath = "C:\TEMP\Export Folder\"
oName = ThisDoc.FileName(False) 'without extension
oDataMedium.FileName = oPath & oName & ".stl"
'write out file.
Call oSTL.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
floyd.schramm
This is not really what I searched for but it will definitely do!
Thanks a lot! Smiley Happy
