Ilogic: Object reference not set to an instance of an object.
sreed
sreed
I have a form in my .idw that fills in my title block and I have a two rules that reach out to the model so that I can change the design state of the model from the .idw.  I can get this to work in a new drawing but when I open and existing drawing and input the form and rules I get errors when it comes to the design state of the model.
I get and error that the "Object reference not set to an instance of an object."  Can some one help me out?
I have attached a .idw and the two rules.
Steve
johnsonshiue
Hi! Is it possible the existing drawing does not have parameter "ModelDesignState" defined?
Many thanks!
Software Test Engineer
chandra.shekar.g
Autodesk Support
Autodesk Support
@sreed,
Try below changes in both iLogic code.
Get Reference assembly
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
oSheet = ActiveSheet.Sheet
oViews = oSheet.DrawingViews
If oViews.Count > 0 Then
	oView = oViews.Item(1)
	oModelName = oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
	Dim referDoc As Document
	referDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
	oAssemblyState = referDoc.PropertySets.Item("Design Tracking Properties").Item("Design Status").Value
	If oAssemblyState = 1 Then
		oAssemblyState = "WorkInProgress"
		Else If oAssemblyState = 2 Then
		oAssemblyState = "Pending"
		Else If oAssemblyState = 3 Then
		oAssemblyState = "Released"
	'MessageBox.Show(oAssemblyState, "Assembly State")
	Parameter("ModelDesignState") = oAssemblyState
Push Design State
Dim oSheet As Sheet
	'MessageBox.Show(oModelName, "Assembly Name")
	oNewState = Parameter.Value("ModelDesignState")
	'MessageBox.Show(oNewState, "Model Design State")
	oAssemblyState = Parameter.Value("ModelDesignState")
	If oAssemblyState = "WorkInProgress" Then
		oAssemblyState = 1
		Else If oAssemblyState = "Pending" Then
		oAssemblyState = 2
		Else If oAssemblyState = "Released" Then
		oAssemblyState = 3
	referDoc.PropertySets.Item("Design Tracking Properties").Item("Design Status").Value = oAssemblyState
	'iProperties.Value(oModelName, "Status", "Design State") = oAssemblyState
 Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
