iLogic: Insert component and modify Positional Representation
I have three components: MyAssy.iam, MySubAssy.iam & MyPart.ipt.
MySubAssy.iam contains two Positional Representations: "Master" and "Up".
I want to insert  and constrain MyPart.ipt inside MySubAssy like:
Components.Add("MyComponent", "MyPart.ipt")
Constraints.AddFlush("Flush:1", "", "YZ Plane", "MyComponent", "YZ Plane", 10)
Constraints.AddFlush("Flush:2", "", "XZ Plane", "MyComponent", "XZ Plane", 20)
Constraints.AddFlush("Flush:3", "", "XY Plane", "MyComponent", "XY Plane", 30)
But in the "Up" position, I want to override "Flush:3" to 100.
MyAssy.iam also contains two positional representations: "Master" and "Open".
I want to insert MySubAssy.iam inside MyAssy.iam, and set positions as:
MyAssy.iam pos "Master": MySubAssy.iam pos is set to "Up".
MyAssy.iam pos "Open": MySubAssy.iam pos is overridden to "Master".
I have attached files that demonstrate desired outcome in Inventor 2019 format, and need code that works with 2019.
Help is greatly appreciated!
Any ideas anyone? Is it even possible to accomplish with iLogic? (so I know to give up if it's not possible)
I found some examples online of people manipulating positional representations, but not to this extent.
