Ilogic code - Run external rule before save (sheetmetal only)
j.wolbers-NoTech
Message 1 of 25
j.wolbers-NoTech
I use an ilogic code that recognizes when there is a bending in a sheet metal part. This code writes "Bend Exist" or "No Bend Exist" to a custom property in the part.
This code is included in the sheet metal template, which means that new files automatically receive this code. But unfortunately there are also parts that do not include this code. When such a part is copied, the code is missing again unless someone happens to think about it.
Now I would like to use this code as an External rule (and therefore also remove it from the template). However, I get the error below when trying to save a regular part (no sheet metal part). How to change the code so that it only runs on a sheet metal part.
Furthermore, I would like to see the "msgbox" close automatically after three seconds or not come up at all.
The ilogic code is stored in the system configuration folder within our Vault environment. So every user can access it. How do I ensure that this external ilogic rule works for all users '' automatically '' ...?
Public Sub Main()
Dim a As Inventor.Application
a = ThisApplication
Dim b As PartDocument
 b = ThisDoc.Document
Dim sm As SheetMetalComponentDefinition
sm = b.ComponentDefinition
MsgBox (sm.Bends.Count)
Dim customProp As Inventor.Property
On Error Resume Next
customProp = b.PropertySets.Item(4).Add("Bend Exist", "Bending")
If Err.Description Then
	Err.Clear
customProp = b.PropertySets.Item(4).Item("Bending")
If sm.Bends.Count > 0 Then
customProp.Value = "Bend Exist"
Else If sm.Bends.Count = 0 Then
customProp.Value = "No Bend Exist"
End Sub
I hope someone can help me with this.
Kinds regards,
Jeffrey
Replies (24)
Message 2 of 25
ianteneth
Hi @j.wolbers-NoTech,
I found a previous post about determining if a part is a sheet metal part or not. Here is the code that checked that as well as the link to that post. Hope this helps!
This code will quit the program if it encounters a non-sheet metal part. You could adapt it to fit your needs.
' If part type equals normal type (non-sheet metal)
If oDoc.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}"
	Exit Sub
https://forums.autodesk.com/t5/inventor-customization/differentiate-sheet-metal-parts-in-ilogic/m-p/...
Message 3 of 25
WCrihfield
There is also a readable way to check Document SubType by the documents iProperty.
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oPropSet As PropertySet = oDoc.PropertySets.Item("Design Tracking Properties")
Dim oProp As [Property] = oPropSet.Item("Document SubType Name")
MsgBox("Document SubType Name = " & oProp.Value)
If the active document is a Sheet Metal type Part document, and you run this codem, it should return "Sheet Metal".
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 25
j.wolbers-NoTech
Hi @ianteneth,
Thanks for your reply.
I tried to implement the code but I get below error. Any idea what I'm doing wrong? Unfortunately I don't know much about ilogic.
And is it possible to ensure that this code is used automatically by all users?
Public Sub Main()
a = ThisApplication
	Err.Clear
End Sub
And is it possible that I want to automatically remove the existing Ilogic code from copied files that already contain an Ilogic code?
This could perhaps be done by looking for an Ilogic rule with the name "Bending" or "Bend" in the file.
Jeffrey
Message 5 of 25
ianteneth
There were quite a few problems with the code you posted. Below is the rewritten code that should do what you want. It will put the number of bends in the sheet metal part in a custom iProperty named "Bending". I checked it and it seemed to work for me.
Public Sub Main()
	' Get the current document
	Dim document As Document = ThisApplication.ActiveDocument
	' Check if document is a part
	If document.DocumentType = kPartDocumentObject Then
		' Check if part is a sheet metal part
		If document.SubType <> "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then
			Dim sheetMetal As SheetMetalComponentDefinition = document.ComponentDefinition
			' Get number of bends
			Dim bendCount As Integer = sheetMetal.Bends.Count
			' Display bend count
			MessageBox.Show(bendCount)
			' Custom iproperty.
			Dim bendCountIProperty As Inventor.Property
			' Try to create iProperty. But it may exist already.
			Try
				bendCountIProperty = document.PropertySets.Item(4).Add("", "Bending")
			Catch
				' Otherwise get the existing iProperty.
				bendCountIProperty = document.PropertySets.Item(4).Item("Bending")
			End Try
			' Check if there are bends or not. Set custom iProperty value.
			If bendCount > 0 Then
				bendCountIProperty.Value = "Bend Exist"
			Else
				bendCountIProperty.Value = "No Bend Exist"
End Sub
Message 6 of 25
ianteneth
And as for your other concerns:
  • Making sure this code is used automatically by every user and every sheet metal part: I have this problem at my work. Users copy old parts or don't use the templates that have the iLogic code in them. I have not found a solution to this other than better training. Maybe someone else can advise us further on this.
Message 7 of 25
WCrihfield
There are ways to inject local rules into other documents from outside those documents.  There is a tool called Code-Injector, that may be able to help with this.  I'm not sure, but it may not be working with the latest version of Inventor at the moment, though.
I also know how to create and place a local rule into a document, using an external rule.  If that sounds like something that would work for you, I can probably help you out with that.
Wesley Crihfield
Message 8 of 25
Darkforce_the_ilogic_guy
just use this
Sub Main()
	Dim doc = ThisDoc.Document
	Dim sDocumentSubType As String = doc.SubType
'Undersøger Document type"
	Try
	If sDocumentSubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then	' = "Sheet Metal"
iProperties.Value("Custom", "Bending")  = "Bend Exist"
iProperties.Value("Custom", "Bending")  = "No Bend Exist"
Catch
End Try
	End Sub
hope this is what you need
Message 9 of 25
you may need to copy
and indset it after Catch...
the code make an error if you save an Emtry doc   or you make want sort of popup  .. your choss of cause
Message 10 of 25
j.wolbers-NoTech
Hi @ianteneth         [@WCrihfield]
Your code works perfectly @ianteneth .
Have only removed the line for the message box so that this pop-up is no longer visible.
Actually, I would like to process in this code as a first step that the ilogic rule with the name bending is removed if it exists. I have quite a few files where the code is processed in the part. And since parts are copied regularly, I would like to remove this specific code first and then run your code. It does not matter to me whether they are 2 separate external ilogic rules or one combined external rule.
Otherwise I run the ilogic rule double and I still get the pop-up.
I really appreciate the help.
Jeffrey
Message 11 of 25
j.wolbers-NoTech
Nobody who can help with this?
Message 12 of 25
marcin_otręba
did you try to search it at this forum in first place ?:
https://forums.autodesk.com/t5/inventor-forum/how-to-use-ilogic-rule-to-delete-rules-and-features-in...
Give me know if it is enough, and you are able to make it work?
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 13 of 25
JelteDeJong
try this rule
Dim oDoc As Document = ThisDoc.Document
If oDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then
    Return
If oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    Return
Dim sm As SheetMetalComponentDefinition = oDoc.ComponentDefinition
Try
    customProp = oDoc.PropertySets.Item(4).Add("Bend Exist", "Bending")
Catch ex As Exception
    customProp = oDoc.PropertySets.Item(4).Item("Bending")
End Try
Try
    Else
    MsgBox("Could not set iProperty 'Bending'. Problay there is none geometry jet")
End Try
Jelte de Jong
Blog: hjalte.nl - github.com
Message 14 of 25
have you try my code ?
Message 15 of 25
sorry i did not read you need samething else too.
You are talking about you want it to be delete when you copy right ?
how are you making an copy ? are you copying in vault ? or save as /save copy as ? or how do you do it ?
if you are using vault you can use action rules in copy design... are you sure you need to delete it  or will an simple update the text/properties not do what you need ?
Message 16 of 25
j.wolbers-NoTech
@marcin_otręba
I have checked this, but unfortunately I do not have enough programming knowledge to familiarize myself with this.
@Darkforce_the_ilogic_guy
I use both methods for copying files.
@marcin_otręba @Darkforce_the_ilogic_guy
I try to explain clearly below what the problem is and what I am trying to achieve.
At the moment I have a lot of files that contain an ilogic code that checks whether there is a bending in the part or not. This code is automatically added to new files since it is included in the sheet metal template.
Unfortunately, there are also files that are older and that do not yet contain this code. Logically, when I copy one of these files, the ilogic code is not included. It is almost impossible to check this manually every time and mistakes are quickly made. Sometimes the code is manually added in such a copied file, but then the '' Ilogic event trigger '' is unfortunately not always set. This means that there is a good chance that information in the custom property is no longer correct.
My idea was to run the ilogic code as an external rule and extract it from the template. As a result, the rule is always executed with sheet metal files.
However, the original Ilogic '' bending '' code must be removed from the copied files, otherwise the code will be run twice (1x in the file itself and 1x as an external rule).
I would also like the message box to no longer be shown, but that has already been resolved. This caused me problems while migrating the CAD data base. Every time this popup came up during the migration process and it doesn't make you happy with thousands of files.
The Ilogic code of @ianteneth  works perfectly. I am only looking for a '' small '' addition.
I hope I have described it a little more clearly.
Kinds regards,
Jeffrey
Message 17 of 25
marcin_otręba
Does your rule have always the same name?, or you want to delete all rules from file ?
Public Sub Main()
			' Custom iproperty.
			Try
			Catch
			End Try
			Else
		If document.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then
		Auto = iLogicVb.Automation
Dim iLogicAuto As Object
iLogicAuto = Auto
Dim oDoc As document
oDoc = ThisApplication.ActiveDocument
'Master file name
If Not (ThisDoc.FileName(False)) = "iLogicPart" Then
	Dim ruleName As String
	Dim rules As Object
	rules = iLogicAuto.rules(oDoc)
		If Not (rules Is Nothing) Then
			For Each rule In rules
				ruleName = rule.Name
    			iLogicAuto.DeleteRule(oDoc, ruleName)
			Next
End Sub
Message 18 of 25
marcin_otręba
or you can use
iLogicAuto.DeleteAllRulesInDocument(oDoc)
instead of
iLogicAuto = Auto
'Master file name
	Dim rules As Object
			Next
Message 19 of 25
j.wolbers-NoTech
Hi @marcin_otręba
The Ilogic rule to be removed is called:
  • Bending (99% of the cases)
  • bending
  • Bend
  • bend
So if it is only possible to delete one Ilogic rule I would like the rule named "Bending" to be removed (because it is the most common).
I don't want all Ilogic rules to be removed as it may contain other rules as well.
When I read your Ilogic code I see that a message box is coming up.
I would like to prevent this.
Or am I not reading your Ilogic code correctly?
Jeffrey
Message 20 of 25
marcin_otręba
This one should delete :
  • bending
  • Bend
  • bend
msgbox commented- will not show.
Public Sub Main()
			'MessageBox.Show(bendCount)
			' Custom iproperty.
			Try
			Catch
			End Try
			Else
iLogicAuto = Auto
'Master file name
	Dim rules As Object
				If Left(ruleName,4).ToLower="bend" Then
			Next
End Sub
