Ilogic code - Run external rule before save (sheetmetal only)
j.wolbers-NoTech
Message 1 of 25
j.wolbers-NoTech
I use an ilogic code that recognizes when there is a bending in a sheet metal part. This code writes "Bend Exist" or "No Bend Exist" to a custom property in the part.
This code is included in the sheet metal template, which means that new files automatically receive this code. But unfortunately there are also parts that do not include this code. When such a part is copied, the code is missing again unless someone happens to think about it.
Now I would like to use this code as an External rule (and therefore also remove it from the template). However, I get the error below when trying to save a regular part (no sheet metal part). How to change the code so that it only runs on a sheet metal part.
Furthermore, I would like to see the "msgbox" close automatically after three seconds or not come up at all.
The ilogic code is stored in the system configuration folder within our Vault environment. So every user can access it. How do I ensure that this external ilogic rule works for all users '' automatically '' ...?
Public Sub Main()
Dim a As Inventor.Application
a = ThisApplication
Dim b As PartDocument
 b = ThisDoc.Document
Dim sm As SheetMetalComponentDefinition
sm = b.ComponentDefinition
MsgBox (sm.Bends.Count)
Dim customProp As Inventor.Property
On Error Resume Next
customProp = b.PropertySets.Item(4).Add("Bend Exist", "Bending")
If Err.Description Then
	Err.Clear
customProp = b.PropertySets.Item(4).Item("Bending")
If sm.Bends.Count > 0 Then
customProp.Value = "Bend Exist"
Else If sm.Bends.Count = 0 Then
customProp.Value = "No Bend Exist"
End Sub
I hope someone can help me with this.
Kinds regards,
Jeffrey
Replies (24)
Message 21 of 25
WCrihfield
I don't know if this will work for your situation or not, but within the Event Triggers dialog box, if you switch to the Parts tab, you could place your external iLogic rule under the "After Open Document" and/or "Before Save Document".  This will work for every Part document, not just the active part document. And if you have those safeguards in the rule that cause it to only work on SheetMetal parts, it shouldn't effect performance of other parts hardly at all.  This is often a good way to deal with all new and old files.
Also there may be a way to use the task scheduler to process a whole directory at a time.
Wesley Crihfield
(Not an Autodesk Employee)
Message 22 of 25
j.wolbers-NoTech
Hi @marcin_otręba
I just tested your code.
The code itself works well!
However, the existing ilogic rule is not yet removed from the file (see image).
I also tried to replace the word '' bend '' with '' Bending '' in the piece of code below. This again shows that I don't understand much of Ilogic...
If Not (ThisDoc.FileName(False)) = "iLogicPart" Then
	Dim ruleName As String
	Dim rules As Object
	rules = iLogicAuto.rules(oDoc)
		If Not (rules Is Nothing) Then
			For Each rule In rules
				ruleName = rule.Name
				If Left(ruleName,4).ToLower="bend" Then
    			iLogicAuto.DeleteRule(oDoc, ruleName)
			Next
End Sub
Kind regards,
Jeffrey
Message 23 of 25
marcin_otręba
Sorry,
i made mistake in line:
instead
If document.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
wchich checks if document is sheetmetal document
i had
document.SubType ="{4D29B490-49B2-11D0-93C3-7E0706000000}"  - wchich is drawing document.
this one :
means that  if 4 chars from word rulename equals to "bend" then true
if you want to change it to word Bending  then go with:
If Left(ruleName,7).tolower="bending" Then
Public Sub Main()
	' Get the current document
	Dim document As Document = ThisApplication.ActiveDocument
	' Check if document is a part
	If document.DocumentType = kPartDocumentObject Then
		' Check if part is a sheet metal part
		If document.SubType <> "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then
			Dim sheetMetal As SheetMetalComponentDefinition = document.ComponentDefinition
			' Get number of bends
			Dim bendCount As Integer = sheetMetal.Bends.Count
			' Display bend count
			'MessageBox.Show(bendCount)
			' Custom iproperty.
			Dim bendCountIProperty As Inventor.Property
			' Try to create iProperty. But it may exist already.
			Try
				bendCountIProperty = document.PropertySets.Item(4).Add("", "Bending")
			Catch
				' Otherwise get the existing iProperty.
				bendCountIProperty = document.PropertySets.Item(4).Item("Bending")
			End Try
			' Check if there are bends or not. Set custom iProperty value.
			If bendCount > 0 Then
				bendCountIProperty.Value = "Bend Exist"
			Else
				bendCountIProperty.Value = "No Bend Exist"
Auto = iLogicVb.Automation
Dim iLogicAuto As Object
iLogicAuto = Auto
Dim oDoc As document
oDoc = ThisApplication.ActiveDocument
MessageBox.Show("a")
'Master file name
	Dim rules As Object
			Next
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 24 of 25
j.wolbers-NoTech
@marcin_otręba, It works!!
I have only changed the following part from: MessageBox.Show ("a") To 'MessageBox.Show (" a ") so that the message box stays away. Otherwise, it will appear twice even if the Ilogic rule has already been removed.
That's not a problem, is it?
Thank you very much for your time and effort!
Kinds regards,
Jeffrey
Message 25 of 25
marcin_otręba
sorry i forgot to delete it. you can delete it or comment it without problem.
