need help with iLogic rules for getting value
bhavik.sutharWZ5M5
bhavik.sutharWZ5M5
I need help with regards to getting values for variables.
Here in the rule, "x2" value is being used for a further round of and addition, To do so, "x2" value comes from measuring the minimum distance between two entity, now I placed to x2 variable in which the only one will suppose to give integer value and other won't because it will be suppressed in an assembly so it pops out the message that so and so component not found.
Is it possible to put any loop or other function which will return me the integer value whether it's in line 1 or line 2 and accordingly use in the subsequent rule?
Line 1:  x2 = Measure.MinimumDistance("M7048-0137, LX0260 50-60Hz:1", "Work Axis1", "G0011-0229:1", "Face0")
Line 2:  x2 = Measure.MinimumDistance("M7048-0137, LX0260 50-60Hz:1", "Work Axis1", "G0011-0416:1", "Face0")
x3 = x2 + 50
x1 = Floor(x3)
MessageBox.Show(x1, "X1")
ianteneth
Hi @bhavik.sutharWZ5M5,
I think you need an IF statement. Here is some pseudo code to achieve this. Let us know if you need help implementing this.
' If G0011-0229:1 is not suppressed Then
' Else If G0011-0416:1 is not suppressed Then
' End If
x3 = x2 + 50
x1 = Floor(x3)
WCrihfield
You could also use the Try...Catch...End Try technique.
Try
	'tries to do this
Catch
	'first option didn't work, so do this instead
End Try
x3 = x2 + 50
x1 = Floor(x3)
Wesley Crihfield
(Not an Autodesk Employee)
