iLogic get preparation drawing view document
Nejc.Leban
Nejc.Leban
Hello everyone,
I'm trying to get the part document of a "Preparation" placed drawing view. On the image below, 10796-07-001-00.iam is the main weldment document. VIEW719 is pos.8 and VIEW720 is pos.11 (10796-06-001-11.ipt). These two are placed on the drawing via Place Views - Base - Model - Preparation(select part), see second image below. What I'm trying to get with iLogic is the part document of each placed view.
Some context - I have automated the placement of views of all occurrences in an assembly. I would now like to check if a view of an occurrence already exists so it doesn't place another view.
I've tried with this:
Dim oViewDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
and this:
Dim viewModelDoc = ActiveSheet.View("VIEW720").ModelDocument.DisplayName
But it gives me the main assembly document and not the part document.
I suppose there's a relatively simple way to get the referenced part, but I can't find it.
I'd really appreciate any suggestions.
Best regards.
Andrii_Humeniuk
Hi @Nejc.Leban .
In this case, you can get an object of type ComponentOccurrence using the DrawingView.GetWeldmentState method. Example iLogic code:
Dim oInvApp As Inventor.Application = ThisApplication
Dim oView As DrawingView
oView = oInvApp.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View...")
If oView Is Nothing Then Exit Sub
Dim eWeld As WeldmentStateEnum
Dim oObj As Object
Call oView.GetWeldmentState(eWeld, oObj)
If Not eWeld = WeldmentStateEnum.kPreparationsWeldmentState Then Exit Sub
Dim oOcc As ComponentOccurrence = oObj
MessageBox.Show(oOcc.Name, eWeld.ToString())
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Nejc.Leban
That works great, thank you!
