iLogic for forming an Excel spreadsheet
negutorthik
negutorthik
Help a beginner to complete the rule. You need to add a column in Excel the amount of sheet material. I haven't slept for the second day.Nothing works out. I hope for your help
'____Create and write to a text file_________________
Try
extension = ".csv"
If (System.IO.File.Exists(ThisDoc.PathAndFileName(False) + extension) = True) Then
System.IO.File.Delete(ThisDoc.PathAndFileName(False) + extension)
End If
sBom = ThisDoc.Document.ComponentDefinition.BOM
sBom.PartsOnlyViewEnabled = True
sBOMView = sBom.BOMViews.Item("Только детали")
Catch
MessageBox.Show("Ошибка 1", "Ошибка")
End Try
Try
For Each sRow In sBOMView.BOMRows
Try
sCompDef = sRow.ComponentDefinitions.Item(1)
If sCompDef.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
Try
If sCompDef.HasFlatPattern = True Then
oFlat = sCompDef.FlatPattern
oStr = sCompDef.Document.DisplayName
oStr = oStr + ";" + (oFlat.Length * 10).ToString
oStr = oStr + ";" + (oFlat.Width * 10).ToString
oStr = oStr + ";" + (sCompDef.Thickness.Value * 10).ToString
oStr = oStr + ";" + (sCompDef.Material.Name).ToString
System.IO.File.AppendAllText(ThisDoc.PathAndFileName(False) + extension, oStr + vbNewLine, System.Text.Encoding.Default)
End If
Catch
MessageBox.Show("Ошибка 2", "Ошибка")
End Try
End If
Catch
MessageBox.Show("Ошибка 3", "Ошибка")
End Try
Next
Catch
MessageBox.Show("Ошибка 4", "Ошибка")
End Try
Try
ThisDoc.Launch(ThisDoc.PathAndFileName(False) + extension)
Catch
MessageBox.Show("Ошибка открытия файла", "Ошибка")
End Try
JelteDeJong
try this:
Dim extension = ".csv"
Try
    If (System.IO.File.Exists(ThisDoc.PathAndFileName(False) + extension)) Then
    End If
    Dim sBom = ThisDoc.Document.ComponentDefinition.BOM
    Dim sBOMView = sBom.BOMViews.Item("Только детали")
    For Each sRow As BOMRow In sBOMView.BOMRows
        Try
            Dim sCompDef = sRow.ComponentDefinitions.Item(1)
                Try
                    If sCompDef.HasFlatPattern Then
                        Dim oFlat = sCompDef.FlatPattern
                        Dim oStr = sCompDef.Document.DisplayName
                        oStr = oStr + ";" + (sRow.ItemQuantity).ToString
                    End If
                Catch
                End Try
            End If
        Catch
        End Try
    Next
Catch
End Try
Try
Catch
End Try
Jelte de Jong
Blog: hjalte.nl - github.com
A.Acheson
Hi @negutorthik
It looks like you have posted multiple messages with the same topic. Please try not to do that as you end up with the same answer multiple times or no responses at all . If you need further assistance just respond to the same post which will bump it to the top. If possible include further information and the attempted code with error messages and a description of what the problem is and you will get better help to the questions asked.
Duplicate post1
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/need-help-exporting-sheet-material-t...
Duplicate post 2
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-for-forming-an-excel-spreadsh...
Regards
Alan
