Need help exporting sheet material to Excel
negutorthik
negutorthik
There is no work experience at Ilogic at all. There is a ready-made rule.Need to insert a column to calculate the quantity. I hope for your responsiveness
'____Create and write to a text file_________________
Try
extension = ".csv"
If (System.IO.File.Exists(ThisDoc.PathAndFileName(False) + extension) = True) Then
System.IO.File.Delete(ThisDoc.PathAndFileName(False) + extension)
End If
sBom = ThisDoc.Document.ComponentDefinition.BOM
sBom.PartsOnlyViewEnabled = True
sBOMView = sBom.BOMViews.Item("Только детали")
Catch
MessageBox.Show("Ошибка 1", "Ошибка")
End Try
Try
For Each sRow In sBOMView.BOMRows
Try
sCompDef = sRow.ComponentDefinitions.Item(1)
If sCompDef.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
Try
If sCompDef.HasFlatPattern = True Then
oFlat = sCompDef.FlatPattern
oStr = sCompDef.Document.DisplayName
oStr = oStr + ";" + (oFlat.Length * 10).ToString
oStr = oStr + ";" + (oFlat.Width * 10).ToString
oStr = oStr + ";" + (sCompDef.Thickness.Value * 10).ToString
oStr = oStr + ";" + (sCompDef.Material.Name).ToString
System.IO.File.AppendAllText(ThisDoc.PathAndFileName(False) + extension, oStr + vbNewLine, System.Text.Encoding.Default)
End If
Catch
MessageBox.Show("Ошибка 2", "Ошибка")
End Try
End If
Catch
MessageBox.Show("Ошибка 3", "Ошибка")
End Try
Next
Catch
MessageBox.Show("Ошибка 4", "Ошибка")
End Try
Try
ThisDoc.Launch(ThisDoc.PathAndFileName(False) + extension)
Catch
MessageBox.Show("Ошибка открытия файла", "Ошибка")
End Try
dalton98
I got this to work. Took out all the try/catch
On Error Resume Next
extension = ".csv"
excel = System.IO.File.Create(ThisDoc.PathAndFileName(False) + extension)
excel.Close
sBOMView = sBom.BOMViews.Item("Parts Only")
End If
End If
Next
negutorthik
I need to add a quantity here.
example: oStr = sCompDef.Quantity
A.Acheson
Hi @negutorthik
The bomrow qty is not contained in the component definition of the part but can be accessed from the bomrow object shown here
Syntax
BOMRow.ItemQuantity() As Long
Syntax
BOMRow.TotalQuantity() As String
Dim qty as String = sRow.TotalQuantity
Regards
Alan
negutorthik
I didn't understand anything).There is absolutely no experience in iLogic. But thank you more for your help
A.Acheson
Hi @negutorthik
Here is the bom row qty added to the string
extension = ".csv"
excel.Close
Dim sBOM As BOM = ThisDoc.Document.ComponentDefinition.BOM
sBOM.PartsOnlyViewEnabled = True
Dim sBOMView As BOMView = sBOM.BOMViews.Item("Parts Only")
For Each sRow As BOMRow In sBOMView.BOMRows
	Dim sCompDef As ComponentDefinition = sRow.ComponentDefinitions.Item(1)
			oStr = oStr + ";" + (sRow.TotalQuantity).ToString
		End If
	End If
Next
and here is another method to get the bom to excel but in traditionally cell values.
Imports XL = Microsoft.Office.Interop.Excel
AddReference "microsoft.office.interop.excel.dll"
Dim xlApp As XL.Application = CreateObject("Excel.Application")
Dim xlWb As XL.Workbook
'comment out or change to false
'in order to not show Excel
xlApp.Visible = True
Dim xlBOMPath As String = "C:\Temp\BomExport.xlsx"
If IO.File.Exists(xlBOMPath) = True Then
	xlWb = xlApp.Workbooks.Open(xlBOMPath)
Else
	 xlWb = xlApp.Workbooks.Add()
	 xlWb.SaveAs(xlBOMPath)
End If
xlWs = xlWb.Worksheets.Item("Sheet1")
'Set Column Headers
xlWs.Range("A4").Value = "DISPLAY NAME"
xlWs.Range("B4").Value = "FLAT PATTERN LENGTH"
xlWs.Range("C4").Value = "FLAT PATTERN WIDTH"
xlWs.Range("D4").Value = "THICKNESS"
xlWs.Range("E4").Value = "MATERIAL"
xlWs.Range("F4").Value = "QTY"
Dim i As Integer = 5
			Dim oFlat As FlatPattern = sCompDef.FlatPattern
			xlWs.Range("A" & i).Value = sCompDef.Document.DisplayName
			xlWs.Range("B" & i).Value = oFlat.Length * 10
			xlWs.Range("C" & i).Value = oFlat.Width * 10
			xlWs.Range("D" & i).Value = sCompDef.Thickness.Value * 10
			xlWs.Range("E" & i).Value = sCompDef.Material.Name
			xlWs.Range("F" & i).Value = sRow.TotalQuantity
			'index to advance To next row
			i=i+1
		End If
	End If
Next
xlApp.Columns.AutoFit
xlWb.Save
'xlWorkbook.Close (False)
'xlApp.Quit
Regards
Alan
negutorthik
Thank you very much. This is what we need. You're the best
