Mouse position in a drawing view
kv5053545
Message 1 of 8
kv5053545
I found this code in the forum but I don't know if it is possible to modify it to have the coordinates inside the view so I can use them to generate dimensions.
    Sub Main()
        Dim oInteraction As InteractionEvents = ThisApplication.CommandManager.CreateInteractionEvents
        Dim oMouse As MouseEvents = oInteraction.MouseEvents
        oInteraction.StatusBarText = "Select a point."
        AddHandler oMouse.OnMouseClick, AddressOf oMouse_OnMouseDown
        oInteraction.Start
    End Sub
    Dim ModelPositionY As Double
    Dim ModelPositionX As Double
    Sub oMouse_OnMouseDown(Button As MouseButtonEnum, ShiftKeys As ShiftStateEnum, ModelPosition As Point, ViewPosition As Point2d, View As Inventor.View)
        ModelPositionX =ModelPosition.X / 2.54
        ModelPositionY = ModelPosition.Y / 2.54
		MessageBox.Show(ModelPositionX)
		MessageBox.Show(ModelPositionY)
    End Sub
Replies (7)
Message 2 of 8
A.Acheson
In what way do you need to modify? The x and y values will be outputted from the mouse rule and you input them to the text position of the dimension. Keeping in mind you might only want to have one of your mouse x or y values to position your dim text otherwise it might not keep it centered. Have you tried a sample rule? Can you attach. I would suggest a simple test case before putting into a more complex rule..
Regards
Alan
Message 3 of 8
kv5053545
It is that when I get those x and y, values I use them to generate dimensions but it places them in a position that it is not.
In this way I obtain the value of the coordinates
dimX =ModelPositionX
dimY = ModelPositionY
Dim linDim1 = genDims.AddLinear("linDim1" & Part, view1.SheetPoint(dimX,dimY), WPlLeft, WPlRight)
Message 4 of 8
WCrihfield
Hi @kv5053545.  Here is a link to the online help pages for that line of code.
IManagedGeneralDimensions.AddLinear Method
IManagedDrawingView.SheetPoint Method
According to the information in that second link (which relates to your View1.SheetPoint() portion of that line of code), those two X & Y values are a percentage of the views size, not absolute positions from the lower left corner of the sheet.  For instance 0.5 would be 50% of the view's width.
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 8
kv5053545
hi @WCrihfield ,Thank you very much, with the links you provided I could understand why the dimensions are not well placed when I put them, but my question now is, is it possible to convert the coordinates so that you can place the dimensions with a mouse click at some random point on the sheet where the user wants the dimension and with this the positions are generated well ?
Message 6 of 8
WCrihfield
Yes, but you would need to use a completely different way of creating dimensions.  You are using the iLogic shortcut snippets with that line of code.  You would need to add them using the Inventor API route, which usually involves a lot more code.  Below is a link to the equivalent Inventor API method.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GeneralDimensions_AddLinear
...and no, that GeneralDimensions is not the same as what you were using in that line of code you had.  What you were working with was the IManagedGeneralDimensions type object.  The API version is just regular GeneralDimensions.  To get to those, you have to go down through the DrawingDocument.ActiveSheet.DrawingDimensions.GeneralDimensions.  And the 'ActiveSheet' in that is not the same as the ActiveSheet iLogic snippet (Link1, Link2) either.  It is an actual property of a DrawingDocument API object.
Wesley Crihfield
Message 7 of 8
kv5053545
Do you have any example that could help me to understand better your idea? I would appreciate it a lot.
Message 8 of 8
WCrihfield
Hi @kv5053545.  I will point you to another Inventor supplied API sample code (also in VBA) for placing a linear foreshortened dimension between two parallel drawing curves in a drawing view.  This sample shows the basics of creating a dimension using the Inventor API route, but it simply specifies a Point2d for where to place the text of the dimension.  In your case though, you would want to replace that line of code with a line of code that calls that mouse position function to run, to capture and retrieve the manual mouse position, so you can use that positional data to specify where to place the dimension's text.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=CreateLinearForeshortenedDimSample_Sample
Although I have automations for creating views in drawings, I do not do much dimensioning or other types of 'attached' annotations in my work drawings by code.  This is primarily because there is far too much variety and differences in all the things that I make drawings for, and automating those types of things requires a certain level of consistency and predictability in the model designs.
Wesley Crihfield
