Unspecified error when setting BSP threads
sdlF9MME
Message 1 of 10
sdlF9MME
Hi.
Im writing a program that changes the type and dimensions of threads for hydraulic ports. Using the an API method (The set.thread function in ilogic is not working properly so this is a workaround). Here is the code.
AINSI threads work normally, but BSP pipe threads results in this error code:
Which doesn't tell me much about the problem.  Am I writing something wrong?
Replies (9)
Message 2 of 10
Frederick_Law
Does Hole1 has correct hole diameter for G 1/2-14?
Message 3 of 10
sdlF9MME
Shoudn't matter in this case no? The function should automatically make a hole of the appropriate diameter? I used this function to change from ANSI unified to NPT for multiple sizes and it never had any problems. I tried experimenting with it but without success.
Message 4 of 10
A.Acheson
The error messages just states one of your variable strings is incorrect. Either look at the dialogue box of the manually selected thread or look to the thread excelsheet to find the correct variable strings to input. I haven't looked at the excel sheet but should there be a G in the Size Designation?
Sample location for thread excel sheet.
C:\Users\Public\Documents\Autodesk\Inventor 202x\Design Data\XLS\en-US\Thread.xls
Regards
Alan
Message 5 of 10
sdlF9MME
Thre is indeed a G in the thread designation. Here is the relevant page:
The thread designation seems to be correctly written. I also copied and pasted the name of the threads, resulting in the same error.
Message 6 of 10
A.Acheson
Looking at the dialogue box the class string is empty despite there being one in the thread sheet.
This works when the class string is left empty.
Dim tapInfo As HoleTapInfo = def.Features.HoleFeatures.CreateTapInfo(True, "BSP Pipe Threads", " G 1/2-14","",True,)
Regards
Alan
Message 7 of 10
sdlF9MME
It indeed works. This is really counterintuitive. Why put classes in the excel sheet if it breaks the function?
Message 8 of 10
Frederick_Law
According to the table, internal thread don't have class.
Class B is empty.
Maybe that's why.
Message 9 of 10
A.Acheson
Hi @Frederick_Law
Your on the money, I didn't really spot that when looking at the table. Every day is a school day.
Regards
Alan
Message 10 of 10
nagihan.bostan
Similarly;
I set the thread type to "ISO Pipe Threads". But I'm getting  error.
Any idea?
//ISO Pipe Threads:
var holeTapInfo = oPartComponentDefination.Features.HoleFeatures.CreateTapInfo(true, "ISO Pipe Threads", " G 1/2", "", true, "20 mm");
