Hi There,
Please can someone help with applying an ilogic rule to all parts within an assembly, I have combined a few ideas to create the rule below, this determines the max cut length assuming that the cut length is always larger than the section size, it then adds this as a custom iproperty "cut length".
This works nicely on individual parts but we want to deploy to all parts within an assembly so that all new BOMs have this information included.
' Get the current Part document.
Dim partDoc As PartDocument = ThisDoc.Document
' Get surface body to measure (assume it's the first body).
Dim body1 As SurfaceBody = partDoc.ComponentDefinition.SurfaceBodies.Item(1)
' Get the oriented mininum range box of the body.
' NOTE: "OrientedMinimumRangeBox" was added in Inventor 2020.3/2021.
Dim minBox As OrientedBox = body1.OrientedMinimumRangeBox
' Get length of each side of mininum range box.
Dim dir1 As Double = minBox.DirectionOne.Length
Dim dir2 As Double = minBox.DirectionTwo.Length
Dim dir3 As Double = minBox.DirectionThree.Length
' Convert lengths to document's length units.
Dim uom As UnitsOfMeasure = partDoc.UnitsOfMeasure
dir1 = uom.ConvertUnits(dir1, "cm", uom.LengthUnits)
dir2 = uom.ConvertUnits(dir2, "cm", uom.LengthUnits)
dir3 = uom.ConvertUnits(dir3, "cm", uom.LengthUnits)
' Sort lengths from smallest to largest.
Dim lengths As New List(Of Double) From {dir1, dir2, dir3 }
lengths.Sort
Dim minLength As Double = lengths(0)
Dim midLength As Double = lengths(1)
Dim maxLength As Double = lengths(2)
iProperties.Value("Custom", "Cut Length") = Round(maxLength, 2)
Thank you, Pete
