I'm trying to reply to this and my replies aren't posting.
Okay, I was able to post without the code and then edit to include it.
Here is the code I found that exported all of the parts as Iges
SyntaxEditor Code Snippet
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'define folder to create files in
oFolder = "c:\temp\IGS Files"
'Check for the destination folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
'format file name
Dim FNamePos As Long
'postion of last back slash
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
Dim docFName As String
'file name with extension
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
'file name without extension
shortname = Left(docFName, Len(docFName) -4)
' Get the IGES translator Add-In.
Dim oIGESTranslator As TranslatorAddIn
oIGESTranslator = ThisApplication.ApplicationAddIns.ItemById _
("{90AF7F44-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oIGESTranslator.HasSaveCopyAsOptions(docFile, oContext, oOptions) Then
' Set geometry type for wireframe.
' 0 = Surfaces, 1 = Solids, 2 = Wireframe
'oOptions.Value("GeometryType") = 1
' To set other translator values:
' oOptions.Value("SolidFaceType") = n
' 0 = NURBS, 1 = Analytic
' oOptions.Value("SurfaceType") = n
' 0 = 143(Bounded), 1 = 144(Trimmed)
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium
'set file path for IGS file
oData.FileName = oFolder & "\" & shortname & ".igs"
oIGESTranslator.SaveCopyAs(docFile, oContext, oOptions, oData)
End If
Next
