Ilogic Enforce Axis constraint undirected
hugo.trepanier
hugo.trepanier
Is it possible to enforce an undirected Axis constraint with an Ilogic rules?
Hugo Trepanier
Autodesk MSD Application Specialist
WCrihfield
By 'enforce', do you mean 'create'?
By 'undirected', do you mean you don't care if the two axes are pointing in the same direction or if they are opposed to each other?
Here are two of the links to the online help pages which document the methods used to add 'insert' type assembly constraints by code.
AssemblyConstraints.AddInsertConstraint Method
AssemblyConstraints.AddInsertConstraint2 Method
And here is another link to another method for adding 'insert' type constraints:
IManagedConstraints.AddInsert Method
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you have time, please... Vote For My IDEAS 💡or you can Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
