Turn imate into regular constraint
Is there a piece of ilogic (or VBA) that turns existing imates into regular assembly constraints ?
I have setup imates to capture the assembly logic of my components.
But I need to be able to update the offset value on these imates to customize my assemblies.
Imates will let you edit the offset values from the parameter menu but will reset to its initial value every time you hit "rebuild all".
My thought process is :
1 - setup the imates
2 - assemble the parts with imates (which helps gain on assembly time)
3 - run some code to turn the imates into regular constraints
4 - edit the constraints
Anyone has a similar idea ?
