find Drawing with missing ballon with Ilogic
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 9
I am trying to make an ilogic program that help finding error and save time in the 2d review faces.
is there a way to check an drawing if all part/assembly on the drawing have ballon? when you have a drawing open you can see if any are missing on the part list ...but I need to check all drawing if anyone is missing .. for  the endgame of making a rapport  that give the user a list of what they need to check on witch drawing
so do anyone know a way to do this ?
Replies (8)
Message 2 of 9
bradeneuropeArthur
Public Sub main
	Dim a As Inventor.DrawingDocument = ThisDoc.Document
	Dim s As Inventor.Sheet = a.ActiveSheet
	Dim pl As Inventor.PartsList = s.PartsLists.Item(1)
	For Each r As Inventor.PartsListRow In pl.PartsListRows
		MsgBox(r.Ballooned)
		Next
	End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
bradeneuropeArthur
Or a bit more useful
Public Sub main
	Dim q As Boolean = True
		If r.Ballooned = False Then
			q = False
		'MsgBox(r.Ballooned)
		Next
		If q = False Then
			MsgBox ("one or more items are not ballooned")
	End Sub
message:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 9
that work on an drawing . but I like to run it on a all the drawing on an assembly
somthing like this... I know the code does not work. but is there a way to find
'Test code
Dim a As Inventor.DrawingDocument = oFS2.GetFile(Left(brow.ReferencedFileDescriptor.FullFileName, Len(brow.ReferencedFileDescriptor.FullFileName) -4) & ".idw")
	Dim q As Integer = 0
q = 0 For Each r As Inventor.PartsListRow In pl.PartsListRows If r.Ballooned = False Then q = q +1 End If 'MsgBox(r.Ballooned) Next 'If q <> 0 Then GoExcel.CellValue(ExcelFile, ExcelSheet, "K" & Row2) = q 'MsgBox (q & " items are not ballooned") 'End If ' End test code
This is my complet code
Class BOMEXport
Shared Row2 As Integer = 3
Shared oDate1 As DateTime
Shared oDate2 As DateTime
Shared oToday As DateTime
Sub main
Row2 =3
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
oBOM.StructuredViewDelimiter = "."
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Structured")
debug("Call ExportToExcel")
Call ExportToExcel(oBOMView.BOMRows)
debug(GoExcel.ToString)
debug("save excel file")
GoExcel.Save
GoExcel.Close
End Sub
Public Function ExportToExcel(brows As BOMRowsEnumerator)
'Dim Row2 As Integer
Try
If Row2 ❤️ Then
Catch
end try
ExcelFile = "C:\Working Folder\CAD\Kallesoe\Kallesoe iLogic\Underdevelopment\ReviewDrawing.xlsx"
ExcelSheet = "CompleteDataSet"
GoExcel.Open(ExcelFile, ExcelSheet)
Dim brow As BOMRow
For Each brow In brows
Dim rDoc As Document
rDoc = brow.ComponentDefinitions.Item(1).Document
Dim docPropertySet As PropertySet
docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
Dim docPropertySet1 As PropertySet
docPropertySet1 = rDoc.PropertySets.Item("User Defined Properties")
Dim docPropertySet2 As PropertySet
docPropertySet2 = rDoc.PropertySets.Item("User Defined Properties")
'item , part number, qty, description, G_L (Custom), Raw material, Status (Custom)
Try
debug(brow.ItemNumber & " Row nr " & Row2)
GoExcel.CellValue(ExcelFile, ExcelSheet, "B" & Row2) = brow.ItemNumber
Catch
End Try
Try
GoExcel.CellValue(ExcelFile, ExcelSheet, "C" & Row2) = docPropertySet.Item("Part Number").Value
Catch
end try
Try
Dim strFileName As String
Dim oFS As Object
strFileName = brow.ReferencedFileDescriptor.FullFileName
oFS = CreateObject("Scripting.FileSystemObject")
'Dato for hvornår den sidste er blevet ændret
oDate1 = oFS.GetFile(strFileName).DateLastModified
GoExcel.CellValue(ExcelFile, ExcelSheet, "D" & Row2) = oDate1
Catch
End Try
Try
GoExcel.CellValue(ExcelFile, ExcelSheet, "U" & Row2) = docPropertySet.Item("Description").Value
Catch
End Try
Dim oFS2 As Object
oDate2 = Nothing
oFS2 = CreateObject("Scripting.FileSystemObject")
Try
oDate2 = oFS2.GetFile(Left(brow.ReferencedFileDescriptor.FullFileName, Len(brow.ReferencedFileDescriptor.FullFileName) -4) & ".idw").DateLastModified
GoExcel.CellValue(ExcelFile, ExcelSheet, "F" & Row2) = "Yes"
Catch
oDate2 = Nothing
GoExcel.CellValue(ExcelFile, ExcelSheet, "F" & Row2) = "No"
End Try
'Test code
q = 0
q = q +1
Next
' End test code
GoExcel.CellValue(ExcelFile, ExcelSheet, "E" & Row2) = oDate2
If oDate2 < oDate1 Or oDate2 = Nothing Then
GoExcel.CellValue(ExcelFile, ExcelSheet, "G" & Row2) = "No"
Else
GoExcel.CellValue(ExcelFile, ExcelSheet, "G" & Row2) = "Yes"
GoExcel.CellValue(ExcelFile, ExcelSheet, "I" & Row2) = right(brow.ReferencedFileDescriptor.FullFileName,3) ' extension
'find docPropertySet.Item("Description").Value
Try
If docPropertySet.Item("Description").Value = docPropertySet1.Item("Part Description").Value Then
GoExcel.CellValue(ExcelFile, ExcelSheet, "J" & Row2) = "No"
Else If docPropertySet.Item("Description").Value <> docPropertySet1.Item("Part Description").Value And docPropertySet.Item("Description").Value = "J" & Row2 <> ""
GoExcel.CellValue(ExcelFile, ExcelSheet, "J" & Row2) = "Yes"
Catch
If docPropertySet.Item("Description").Value = "" Then
Else
GoExcel.CellValue(ExcelFile, ExcelSheet, "J" & Row2) = "yes"
End Try
debug("Item nr. " & brow.ItemNumber)' & "part number " &docPropertySet.Item("Part Number").Value & "qty " & brow.ItemQuantity & "description " & docPropertySet.Item("Description").Value & "Length " & docPropertySet1.Item("G_L").Value & "Raw Material " & docPropertySet1.Item("Raw Material").Value & "Status " &docPropertySet1.Item("Status").Value)
Row2 = Row2 + 1
If Not brow.ChildRows Is Nothing
Call ExportToExcel(brow.ChildRows)
Next
End Function
Public Sub debug(txt As String)
Trace.WriteLine("NTI : " & txt)
End Sub
End Class
Message 5 of 9
That is a different question.
You need to run the code in the assembly to see if all parts and  sub-assemblies have been ballooned, right?
First question how do you know on which drawing the assembly is (only) drawn/used. it can be an different drawings.
If you are using Vault-pro, You could use the Vault API for it, but only with inventor it is hard to find.
There is a where used function in Inventor API but that only works if the drawings are all opened already.
So that will not bring a lot!
Please can you give me an answer to these questions?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 9
yes. I want to run the code in the assembly to see if all parts and  sub-assemblies have been ballooned. well part is not needed sind we are not balloned part drawing. sind there is always only one componemt to ballooned
the drawing is always at the same location as the 3d file.
so I can do a code like this to get the fullfilename and location on the drev
 for now I simple want to information need to see with files you might need to look as for missing ballooned
I am trying to make a larger program that find error that human easyly mis.  for now I can check  if
  1. you forgot to update your 2d after change 3d files
  2. if there is a drawing at all
  3. and if the drawing is old ... so we save time by not  reviewing old drawing again and again
  4. check if an weigt was added to new purchased  part , like motor  cylinder and stuff like that
chekcing for ballons is not the next level I wanted to add 😉
Message 7 of 9
pl.sivakumar
Public Sub Main
			q = False
		Next
		If q = False Then
	End Sub
Above rule I kept in the trigger, Working good in the assembly drawing, But the Part drawing shows  below error
"Error on line 5 in rule: Missing Balloons, in document: 22030.08.002-00.idw
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
Message 8 of 9
pl.sivakumar
All are working good in the assembly drawing
The same rule is kept in the trigger, While running in  part drawing the following error shown, Can possible to support
Error on line 11 in rule: Missing Balloons, in document: part.idw
Message 9 of 9
pl.sivakumar
Code updated, Now it will work in Trigger
Public Sub Main
Dim oDoc As DrawingDocument = Nothing
Try ' Is it a drawing?
oDoc = ThisApplication.ActiveEditDocument
Catch
MsgBox("This iLogic rule only works with drawing documents!")
Return
End Try
If s.PartsLists.Count = 0 Then
	Exit Sub
q = False
Next
If q = False Then
MessageBox.Show("Balloon Missing", "Warning")
End Sub
