iLogic driven BOM
iLogic driven BOM
Formsprag
iLogic driven BOM
Formsprag
Looking a little help with a BOM problem. I have a iLogic driven configurator that simply switches between view reps to build each configuration. Model works beautifully except the BOM shows everything in the Master. What is the most efficient way to get the BOM to only display visible components for the Active view rep?
I've seen older posts about creating a custom LoD named "iLogic" and I've seen posts stating to stay away from LoDs.
I simply do not want non-visible components to show up in the BOM each time the configurator is run.
Inventor 2020
marcin_otręba
If something should not be visible in BOM window in assembly enviroment then its BOM structure should be set to be reference but it will affect only 2 views : structured and parts only. It can be set inside each assembly to do not affect document definition, so in one assembly it will be reference and in another default.
Ity can be done thru occurrence:
Dim occ As ComponentOccurrence
For Each occ In ThisDoc.Document.componentdefinition.occurrences
occ.BOMStructure = kReferenceBOMStructure
next
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Formsprag
OK, can this rule be made to only change non-visible components to reference? It would need to be able to switch components between "Normal" and "Reference" based on the visibility of each component in the view rep.
marcin_otręba
try:
if occ.visible=true then occ.BOMStructure = kReferenceBOMStructure
end if
next
Ideas
or check my apps:
Formsprag
Thank you for your help, here's what I ended up with for the .iam
Any idea how to make this work for an .idw?
'Set Bill of Material Structure
	If occ.Visible = True Then
	occ.BOMStructure = kDefaultBOMStructure
	Else If occ.Visible = False Then
End If
Next
marcin_otręba
you want to make this in drawing partslist ? or you want to get acces to assembly bom from drawing?
Ideas
or check my apps:
bradeneuropeArthur
In the drawing you can use the "Filter" function to do this.
With the filter you can filter based on View Representation and visibility and other methods.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
