iLogic decimal
iLogic decimal
Cosmin_V
Message 1 of 8
iLogic decimal
Cosmin_V
Hi Everybody,
I have an iLogic assembly in which I what to see the value of 2 angels from a part.
For this I wrote this line.
Front_L_Angle = Parameter(oBin.Name,  "d45")
Front_R_Angle = Parameter(oBin.Name,  "d49")
If the "d45" is =37,56 deg. I dont understend why Front_L_Angle is = 37,5685920288275 deg.
Can the code be improved to show only 2 decimal?
Many thanks!
Replies (7)
Message 2 of 8
Justin.B.
Round(Front_L_Angle,2)
Message 3 of 8
bradeneuropeArthur
You need a kind of round-down:
Floor is the function you need:
Public Sub main
	Dim a As Double
	a = 1.23456
	MsgBox (floor(a*100)/100)
	End Sub
Round Down:
Ceil is the function you need then
Public Sub main
	Dim a As Double
	a = 1.23456
	MsgBox (Ceil(a*100)/100)
	End Sub
What you need is:
Public Sub main
	Dim a As Double
	a = 1.23456
	MsgBox (floor(d45*100)/100)
	End Sub
Like this:
Parameter("Front_L_Angle") = "floor(d45 / 1 deg * 100 ul) / 100 ul * 1 deg"
Parameter("Front_L_Angle") = "floor(d49 / 1 deg * 100 ul) / 100 ul * 1 deg"
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 8
Cosmin_V
Hi
Thanks, but no one of this codes are not working. 😞
Message 5 of 8
bradeneuropeArthur
could you upload the ipt file?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 8
Cosmin_V
No, unfortunately Im not aloud…:(
Message 7 of 8
bradeneuropeArthur
can you make a snapshot of the parameterbox
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
Cosmin_V
I create something similar whit the original...I hope is useful….
