Update browser after replace reference in Presentation file
j_steenbergen
j_steenbergen
I've made a little vba code which replaces the model reference in a Presentation file and it works like a charm.
But there's one small issue, which is that the name of the referenced model in the browser isn't updated until you reopen the document. If you expand the model you see the right children though.
The model name can't be manually changed so I was wondering if there's any possibility to update the model browser in a Presentation file through VBA?
JelteDeJong
in some cases it helps to reset the display name. that can be done be setting the displayname to an emty string. something like this:
Dim oDoc As PresentationDocument
oDoc.DisplayName = ""
Jelte de Jong
Blog: hjalte.nl - github.com
j_steenbergen
Thanks but it doesn't concern the displayname of the file in the model brower (filename.ipn). It's about the name of the referenced model (filename.iam), which you see if you expand the explosion in the model browser. It can be reached through:
ThisApplication.ActiveDocument.File.ReferencedFileDescriptors(1)
But using displayname for the item returns an error, and if I look at the locals window it's because the item doesn't have a displayname property. It does have a "RelativeFileName" property though, but that's read-only.
