iLogic - Creating Structured Parts List
JoãoASilva
Message 1 of 9
JoãoASilva
Hello everyone and Happy New Year! 😎
I came across this thread about automatically placing a Parts List in a drawing.
After a few tweaks, got it *almost* working as I need it to.
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
'Detect if the template has a parts list
Try
	Dim oPartslistCheck As PartsList
	oPartslistCheck = oSheet.PartsLists(1)
	partslistpresent=True
Catch
	partslistpresent=False
End Try
If partslistpresent=True
	'Delete the current parts list
	Dim oPartsList As PartsList
	oPartsList = oDrawingDoc.ActiveSheet.PartsLists.Item(1)
	oPartsList.Delete
End If
' Set a reference to the first drawing view on
' the sheet. This assumes the first drawing
' view on the sheet is not a draft view.
Dim oDrawingView As DrawingView
oDrawingView = oSheet.DrawingViews(1)
' Set a reference to the sheet's border
Dim oBorder As Border
oBorder = oSheet.Border
' Set a reference to the sheet's title block
Dim oTitleBlock As TitleBlock
oTitleBlock = oSheet.TitleBlock
'['Temporary Parts List
Dim oPlacementPoint As Point2d
	xrev = 0
	yrev = 0
	oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(xrev, yrev)
' Create the parts list
Dim oPartsList1 As PartsList
oPartsList1 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
'['Definitive Parts List
Dim oPlacementPoint2 As Point2d
	xrev2 = oTitleBlock.RangeBox.MaxPoint.X - 0.5
	yrev2 = oTitleBlock.RangeBox.MaxPoint.Y - oPartsList1.RangeBox.MinPoint.Y
	oPlacementPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(xrev2, yrev2)
' Delete Temporary Parts List
oPartsList1 = oDrawingDoc.ActiveSheet.PartsLists.Item(1)
oPartsList1.Delete
' Create Definitive Parts List
Dim oPartsList2 As PartsList
oPartsList2 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint2, PartsListLevelEnum.kFirstLevelComponents)
oPartsList2.Sort("PART NUMBER")
oPartsList2.Renumber
oPartsList2.Style.UpdateFromGlobal
'Switch style back and forth to ensure style is up-to-date
oPartsList2.Style = oDrawingDoc.StylesManager.PartsListStyles.Item("Parts List (ISO-AIP)")
oPartsList2.Style = oDrawingDoc.StylesManager.PartsListStyles.Item("Parts List (ISO)")
InventorVb.DocumentUpdate()
Only thing left is to create a Parts List with a "Structured BOM View".
When I manually select "Structured (legacy)", I get to expand the Parts List and see all sub-assemblys:
But I can't find how to get the rule to do so:
Any thoughts?
João Silva
Mechanical Engineer
Replies (8)
Message 2 of 9
dutt.thakar
@JoãoASilva
Can you change this line in your code, when you are placing Definitive parts list?
oPartsList2 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint2, PartsListLevelEnum.kStructuredAllLevels)
See if it works.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Message 3 of 9
JoãoASilva
@dutt.thakar
If I change that it gives an error.
Expected, since it only accepts kFirstLevelComponents and kPartsOnly.
But I found how I can change it manually:
I'm trying to get here, thru code, when run on the drawing document.
Any inputs are welcome.
João Silva
Mechanical Engineer
Message 4 of 9
dutt.thakar
@JoãoASilva
What I would suggest you is to take a model document from the drawing reference and then you can reference its BOM object from iLogic and in BOm you can set the structured view and also the all levels.
I think you can see this link may be a help.
https://forums.autodesk.com/t5/inventor-customization/ilogic-bom-enabled-for-all-child-assemblies/m-...
Dutt Thakar
LinkedIn
Message 5 of 9
JoãoASilva
@dutt.thakar
I was replying with exactly that!
I found a way to reach the BOM of the model in the drawing:
' get model doc
Dim oModelDoc As Document
oModelDoc = ActiveSheet.View(oDrawingView.Name).ModelDocument
' get the BOM database
oBOM = oModelDoc.ComponentDefinition.BOM
' Make sure the BOM view is enabled
oBOM.StructuredViewEnabled = True
' Make sure the BOM first level is disabled
oBOM.StructuredViewFirstLevelOnly = False
' Set the delimiter for the BOM view
oBOM.StructuredViewDelimiter = "."
And this works perfectly!
The problem now is that I get an error: HRESULT: 0x80070057
From what I have seen, it has to do with the temp file, wich has to be deleted.
Sometimes the rule works, other times it doesn't.
And the part that is giving an error is:
 I placed a "return" before (nothing happend), and placed a "return" after and got that error.
João Silva
Mechanical Engineer
Message 6 of 9
dutt.thakar
@JoãoASilva
I tried the code in my assembly and I got the same error here : oPartsList.Sort("PART NUMBER") , This has happened because I don't have the same column in my BOM so when I changed the column name in "oPartsList.Sort", The error is resolved. Apart from that everything works perfectly.
Is it possible for you to attach your assembly and drawing here, so I can try and look in to it?
Hope this is helpful.
Dutt Thakar
LinkedIn
Message 7 of 9
JoãoASilva
@dutt.thakar ,
In my case, it doesn't even reach that part 😅
I've attached the files for you to test. Hope none are missing.
I've included a copy of my rule, in a .txt format.
Can't yet figure out why the rule runs sometimes, other times it doesn't.
Even though the conditions seem to be the same...
João Silva
Mechanical Engineer
Message 8 of 9
dutt.thakar
@JoãoASilva
Thanks for providing the files, The thing that was happening with your code is if you are updating the structure and all levels in the assembly, then you need to place the parts list with kStructuredAllLevels enum. I just changed a bit in your code, and it worked. see below code. I also added one mode thing when you are updating BOM level in model document, I added two lines, one is to rebuild the model and another is to save after you enable all levels.
If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
	Dim a As String = a
Else
	MessageBox.Show("This Rule can only be executed on the following documents:" & vbNewLine _
	& " • Drawing", "Rule not executed!" & " • " & iLogicVb.RuleName, MessageBoxButtons.OK, MessageBoxIcon.Error)
	Return
End If
Dim oSheet As Sheet
Try
Catch
End Try
	oPartsList.Delete
End If
oDrawingView = oSheet.DrawingViews.Item(1)
'['Update BOM to Structured View
' get model doc
oModelDoc.Rebuild2
oModelDoc.Save
	xrev = 1
	yrev = 1
'' Create the parts list.
oPartsList1 = oSheet.PartsLists.Add(oDrawingView,oPlacementPoint,PartsListLevelEnum.kStructuredAllLevels) '<- This line gives me the error HRESULT: 0x80070057, but not everytime...
oPartsList1.Delete
oPartsList2 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint2,PartsListLevelEnum.kStructuredAllLevels)
Hope this will help.
Dutt Thakar
LinkedIn
Message 9 of 9
JoãoASilva
@dutt.thakar
Thank you for your help, this way it worked on all files! 👊
The rule got slower because it needs to rebuild and save, but i'm fine with it.
Now I just need to adjust the placement of the Parts List and it's ready to be implemented.
Kudos!
João Silva
Mechanical Engineer
