ilogic automactly place parts list
Message 1 of 23
Hi All,
When placing a base view, I would like to have the part list inmediatly placed on the top right border. I have different parts list styles. One for assemblies, and one for individual parts. Is there a way to also incorporate this in the Ilogic rule?
Accepted solutions (3)
Replies (22)
Message 2 of 23
waynehelley
Sorry that its a bit messy but here is some logic I wrote a long time ago for placing a Parts List.  I'm not quite sure how you would go about getting the logic to automatically trigger when you place a drawing view.
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
'Detect if the template has a parts list
Try
Dim oPartslistCheck As PartsList
oPartslistCheck = oSheet.PartsLists(1)
partslistpresent=True
Catch
partslistpresent=False
End Try
If partslistpresent=True
        'Delete the current parts list
        Dim oPartsList As PartsList
        oPartsList = oDrawingDoc.ActiveSheet.PartsLists.Item(1)
        oPartsList.Delete
    ' Set a reference to the first drawing view on
    ' the sheet. This assumes the first drawing
    ' view on the sheet is not a draft view.
    Dim oDrawingView As DrawingView
    oDrawingView = oSheet.DrawingViews(1)
    ' Set a reference to the sheet's border
    Dim oBorder As Border
    oBorder = oSheet.Border
    Dim oPlacementPoint As Point2d
        xrev = oBorder.RangeBox.MaxPoint.X
        yrev = oBorder.RangeBox.MaxPoint.Y
        oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(xrev, yrev)
    ' Create the parts list.
    Dim oPartsList1 As PartsList
    oPartsList1 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
oPartsLis1t = oDrawingDoc.ActiveSheet.PartsLists.Item(1)
oPartsList1.Sort("PART NUMBER")
oPartsList1.Renumber
oPartsList1.Style.UpdateFromGlobal
'Switch style back and forth to ensure style is up-to-date oPartsList1.Style = oDrawingDoc.StylesManager.PartsListStyles.Item("Parts List (ANSI)") oPartsList1.Style = oDrawingDoc.StylesManager.PartsListStyles.Item("Parts List (ISO)") InventorVb.DocumentUpdate()
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Message 3 of 23
Thank you for this code. Placing the parts list works well. But regardless if it is an .iam or .ipt, it still places the parts list with the same style. Can you help me with that last part
Message 4 of 23
waynehelley
Using something like this should work.
Dim oRefDocType As DocumentTypeEnum
oRefDocType = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocumentType
Select Case oRefDocType
Case DocumentTypeEnum.kPartDocumentObject
   MsgBox("This is a part")
Case DocumentTypeEnum.kAssemblyDocumentObject
    MsgBox("This is an assembly")
End Select
Wayne Helley
Visual Studio 2022
Message 5 of 23
Thanks!!!
Message 6 of 23
Any idea's why this wouldn't work with Inventor 2018?
It fails on this line
Message 7 of 23
MechMachineMan
@Anonymous
There could be a lot of reasons, which I addressed in the other thread. But a more wordy reasoning of why it might not work:
1. The variable you are trying to assign it to is not the proper type for what the function returns - or the function may not even be a function, and may have no return value, in which case it also wouldn't work. If you were to have oPartsList1 typed as anything but a parts list somewhere else in the code, it wouldn't work.
2. You are not providing a proper "parent" for the function call. If oSheet is not in fact a Sheet, it would not work.
3. The parameters you are trying to pass the method call are not proper. You need to look up the documentation in the API regarding this as it is different for every method, and there are often exceptions that are documented there ****** THIS IS VERY OFTEN THE CASE****
4. You could have things spelled wrong.
5. There could be invisible characters on the line
6. Syntax could be wrong depending if you are using VB or VBA
7. It could just be an invalid method/operation - which kind of goes back to Item 2. If the oSheet belongs to a drawing document that already has a different type of partslist placed somewhere, it could also fail.
8. The things you are doing are not possible through the UI for valid reasons... Sometimes you can do extra things through API that you can't through UI, but the default assumption should be that if you can't do the steps through the UI without error, then you probably can't do it through the API without error.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 8 of 23
milan5
HI,
My name is Milan.
I am new to API and codes, recently tried this code for BOM placing in inventor but didnot work for me.
Can anyone guide me how to exactly run this code.
Regads,
Milan Kantaria
Message 9 of 23
MechMachineMan
@milan5 Google is the most powerful tool of the 21st century, and if you use proper keywords, you can usually find answers to your questions.
For Example, if I google "Autodesk Inventor + iLogic + how to use rule"
the first link that pops up is quite valuable. As is the 2nd link, and so on and so forth.
There are also tutorials done by Autodesk on the topic.
However, noted below is also pretty much the exact same steps that
Step 1: Identify if code is VB or VBA:
           - There are no variable assignment lines that begin with "set", so we can guess this is likely vb.net - which is used in the rule environment.
Step 2: Enable the iLogic browser.
           - In the ribbon bar: Tools > Addins. Ensure iLogic is set to load automatically, and is loaded.
           - Also in the ribbon bar (while you have a document open:): View > User Interface. Ensure iLogic Browser is checked
Step 3:
          - Copy the code from the forums.
Step 4:
         - In the iLogic Browser, go to the external rules tab.
         - Right click the "Standard Directories"
         - Click "Create New External Rule"
         - Establish the file name
         - Paste the copied code from the forums into the rule editor window that pops up.
         - Click Save
         - Close the rule dialog
Step 5:
         - Right click the rule name in the iLogic browser
         - Click "Run Rule"
Justin K
Message 10 of 23
I know this is an old thread but I was reading through and saw that the question regarding the error on the "PartsLists.Add()" line may not have gotten an answer.  If you're doing this in VBA you'll need to put a "Set" keyword in front of that line.  It should look something like this:
Set oPartsList1 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
Message 11 of 23
galin.filipov
Try this code instead of the short one.
oPartsList1 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint, PartsListLevelEnum.kStructuredAllLevels)
It works in my case. You need to add  "PartsListLevelEnum. ...." .
Message 12 of 23
@waynehelley , What i have to do to move partlist to top left corner.
Thank
Message 13 of 23
waynehelley
I think you would just need to replace 'MaxPoint' with 'MinPoint' for the x-axis.
Wayne Helley
Visual Studio 2022
Message 14 of 23
@waynehelley , i already repalced but the position seems still wrong like this
I think we need to calculate partlists frame size then + with it, but when i replaced this
xrev = oBorder.RangeBox.MinPoint.X
by this one
xrev = oBorder.RangeBox.MinPoint.X + (oPartsList.RangeBox.MaxPoint.X - oPartsList.RangeBox.MinPoint.X)
then run rule it said
Error on Line 37 : 'oPartsList' is not declared. It may be inaccessible due to its protection level.
here is my code
Dim oSheet As Sheet
Try
Catch
End Try
        oPartsList.Delete
Message 15 of 23
JBerns
@galin.filipov,
Thank you for your suggestion to add the PartsListLevelEnum option.
I had similar code to above which worked for most assemblies, but failed on a few.
The few that failed I discovered had BOM 'Structured' and 'Parts Only' tabs both enabled.
Apparently the iLogic code could not decide which level to use.
Problem solved with your code. Well done!
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 16 of 23
JBerns
Our top-level assemblies use BOM 'Structured', while most subassemblies use BOM 'Parts Only'.
I will need to test the assembly to see which level is available.
'StructuredAllLevels' option seems to fail if that BOM tab has not been enabled in the assembly.
I am using Try-Catch statements, but will search for a better solution.
CAD Administrator
Message 17 of 23
JMGunnar
i found too solve error
switch in viewproperites  to firstlevel
Best Regards Johan
@JBerns
Message 18 of 23
MichaëlStienstra
Thomas Fitzgerald has written some code with the same outcome. The partlist is positioned in the upright corner of the active document.
https://github.com/AlexFielder/iLogic/blob/master/Autodesk/Thomas%20Fitzgerald/Parts%20List.iLogicVb
Message 19 of 23
MichaëlStienstra
This is the code I am using now. The list is located on the up left corner of the drawing. If you want it is pretty easy to change the position with use of lines 12 and 13.
Sub Main
 Dim invDoc As DrawingDocument = ThisApplication.ActiveDocument
 Dim oSheet As Sheet = invDoc.ActiveSheet
 Try
 DeletePartsList(oSheet)
 Catch
 End Try
 Dim oDrawingView As DrawingView = oSheet.DrawingViews(1)
 Dim oBorder As Border = oSheet.Border
 If Not oBorder Is Nothing Then
	xrev = oBorder.RangeBox.MinPoint.X+"17"
Dim partsListBomType As PartsListLevelEnum = 46593
 Dim oPartsList As PartsList = oSheet.PartsLists.Add(oDrawingView,
oPlacementPoint, partsListBomType)
End Sub
Private Sub DeletePartsList(oSheet As Sheet)
 Dim oPartList As PartsList
 For Each oPartList In oSheet.PartsLists
 oPartList.Delete()
 Next
End Sub
Message 20 of 23
engineeringSEZWD
@MichaëlStienstrathis Ilogic rule worked well for me, however I want to change the style as I have 3 different part list but can i identify the correct PartsListLevelEnum = ?????
thank you
as you can see in the picture, the ilogic rule add the parts list (iso) template, but I want to add the Cut list (ISO) templete for all drawing that are frames
