iLogic Create Part List on a Sheet by selecting Balloons on Drawing Views
checkcheck_master
checkcheck_master
Hi there,
Through a Drawing with several sheets we try to create an instruction manual based on an assembly.
Next, on a certain sheet, we like to have a Parts Lists with only the items which are Ballooned in certain views on that sheet.
The Parts List filter 'Ballooned Item Only' is not limited to that certain sheet with as result that on every sheet with a Parts List the Ballooned items appear.
Hidding the rows(what we do now) is not an alternative with 20 or more sheet to manage.
Is it possible with ILogic to place a 'Parts List Body'(without rows) and add rows by selecting Balloons?
Something like(just an idea):
'Select Balloon(s) and do things
While True
Dim oBalloon As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kBalloonFilter, "Select a Balloon to add a Parts List Row")
     If Not oBalloon Is Nothing Then
	oBalloon.addRowToPartsList = True
     End If
If
IsNothing(oBalloon) Then Exit While
End While
Anyone?
Thanks in advance.
Greetings!
bradeneuropeArthur
No code needed for that.
It is already in the inventor filter of the partlist.
Filer on show only ballooned items!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
checkcheck_master
Thanks for your reaction,
Please check as described:
Did we miss an option to get rid of that behavior?
Greetings!
bradeneuropeArthur
Could you send a pdf of the drawing to see what you need?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
