Ilogic Count all Normal components in Assembly
j.romo
Message 1 of 14
j.romo
I couldnt find anything like this in the forum.
I need to know how many total Normal parts are in the master assembly, including sub assemblie components, to give me a total number of NORMAL parts, wich we manufacture in our shop, so we can calculate the manufacturing progress vs the total number of parts it can be a custom parameter that can be filled in the master assembly.
Thanks in advance
PD I dont even know how to start this. Man Sad
Replies (13)
Message 2 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@j.room,
Hoping that below iLogic code would help to get number of parts in Assembly(Includes all sub assembly).
Sub Main()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition
    oAsmDef = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
    oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through the occurrences and print the name.
	Dim cnt As Integer
	cnt = 0
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
        If oOcc.BomStructure = BOMStructureEnum.kNormalBOMStructure Then
			cnt = cnt + 1
			MessageBox.Show(oOcc.Name)
		End If
    Next
	MessageBox.Show(cnt)
End Sub
For more details on accessing assembly components, refer the below blog article link.
http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 14
AlexFielder
I have this old rule (linked in case I change/update it for any future reader) which does this as well as adding it to a custom iProperty:
(My rule doesn't filter by "Normal BOM state" however but this could be accomplished by combining with @chandra.shekar.g's post!)
Imports Inventor
Imports System.IO
Public Sub Main
If TypeOf ThisDoc.Document Is PartDocument Then
PartFeatureCount(ThisDoc)
Else
RunFeatureCount(ThisDoc.Document)
End If
MessageBox.Show("Done!")
End Sub
Public Sub RunFeatureCount(ByVal oDoc as Inventor.Document)
	Dim oAssy As inventor.AssemblyDocument
	Dim oSubDoc as Inventor.Document
	If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
		oAssy = CType(oDoc,AssemblyDocument)
		AssemblyFeatureCount(oAssy)
		For Each oComp In oAssy.ReferencedDocuments
			'oSubDoc = CType(oComp.Definition.Document,Document)
			'MessageBox.Show(oSubDoc.File.FullFileName)
			If oComp.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
				'run FeatureCount and then call RunFeatureCount to recurse the assembly structure
				'iLogicVb.RunExternalRule("FEATURECOUNT")
				FeatureCount(oComp)
				RunFeatureCount(oComp)
			Else
				'run FeatureCount
				FeatureCount(oComp)
			End If
		Next
	ElseIf oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
		FeatureCount(oDoc)
	End If
End Sub
Sub FeatureCount(ByVal oDoc as Inventor.Document)
	Try
	Dim SaveRequired As Boolean = False
	'uncomment for debugging purposes!
	'MessageBox.Show(DocName)
		If TypeOf oDoc Is PartDocument Then
			If Not oDoc.File.FullFileName.Contains("Content") And Not oDoc.File.fullfilename.contains("FACILITY") And Not oDoc.File.fullfilename.contains("Imported Components") Then 'skip CC and FACILITY files
				Dim PartDocName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.DisplayName) & ":1"
				Dim oFeats as PartFeatures = oDoc.ComponentDefinition.Features
				Dim oParams as Parameters = oDoc.ComponentDefinition.Parameters
				Try
					If Not iProperties.Value(PartDocName,"Custom", "FEATURECOUNT") = oFeats.Count Then 'or update it
						SaveRequired = True
					End If
					'MessageBox.Show("Feature Count for this part is: " & oFeats.Count, "FEATURECOUNT")
					If Not iProperties.Value(PartDocName,"Custom","PARAMETERCOUNT") = oParams.Count Then 'or update it
						SaveRequired = True
					End If
					'MessageBox.Show("Parameter Count for " & oDoc.File.fullfilename &" is: " & oParams.Count, "PARAMETERCOUNT")
					If SaveRequired Then
						'oDoc.Save 'try to save the file.
					End If
				Catch
					Exit Sub
				End Try
			End If
		ElseIf TypeOf oDoc Is AssemblyDocument Then
				Dim DocName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.DisplayName) & ":1"
				Dim oFeats as Features = oDoc.ComponentDefinition.Features
				Dim Occs as ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
				'Dim oConstraints as Constraints = oDoc.ComponentDefinition.Constraints
				Try
					If Not iProperties.Value(DocName,"Custom", "FEATURECOUNT") = oFeats.Count Then
						SaveRequired = True
					End If
					'MessageBox.Show("Feature Count for this assembly is: " & oFeats.Count, "FEATURECOUNT")
					If Not iProperties.Value(DocName, "Custom", "OCCURRENCECOUNT") = Occs.Count Then
						SaveRequired = True
					End If
					'MessageBox.Show("Occurrence Count for " & oDoc.File.fullfilename & " is: " & Occs.Count, "OCCURRENCECOUNT")
					If Not iProperties.Value(DocName, "Custom","PARAMETERCOUNT") = oParams.Count Then
						iProperties.Value(DocName, "Custom", "PARAMETERCOUNT") = oParams.Count
						SaveRequired = True
					End If
					'MessageBox.Show("Parameter Count for this part is: " & oDoc.ComponentDefinition.Constraints.Count, "PARAMETERCOUNT")
					If Not iProperties.Value(DocName, "Custom","CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count Then
						iProperties.Value(DocName,"Custom", "CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count
						SaveRequired = True
					End If
					'MessageBox.Show("Constraint Count for Assembly " & DocName & " is: " & oDoc.ComponentDefinition.Constraints.Count, "CONSTRAINTCOUNT")
					End If
				Catch
					'creates any missing iProperties.
					'oDoc.Save 'saves the assembly
					Exit Sub
				End Try
			End If
		End If
	Catch ex As Exception
		'MessageBox.Show("The error is: " & ex.Message & vbCrLf & ex.StackTrace,oDoc.DisplayName)
	End Try
End Sub
Sub PartFeatureCount(ByVal oDoc)
	Try
			Dim oFeats as PartFeatures = oDoc.Document.ComponentDefinition.Features
			Dim oParams as Parameters = oDoc.Document.ComponentDefinition.Parameters
			Try
				'may need to save the file when we're done, hence the boolean check
				If Not iProperties.Value("Custom", "FEATURECOUNT") = oFeats.Count Then
					SaveRequired = True
				End If
				If Not iProperties.Value("Custom","PARAMETERCOUNT") = oParams.Count Then
					SaveRequired = True
				End If
				'MessageBox.Show("Parameter Count for " & oDoc.Document.File.fullfilename &" is: " & oParams.Count, "PARAMETERCOUNT")
				End If
			Catch
				'definitely need to save the file!
				'oDoc.Close 'try to close the file - on a vaulted file this will fire the check-in dialogue.
			End Try
		End If
		'MessageBox.Show("The error is: " & ex.Message & vbCrLf & ex.StackTrace)
	End Try
End Sub
Sub AssemblyFeatureCount(ByVal oDoc)
	Try
		'Dim DocName As String = oDoc.DisplayName
			Try
					SaveRequired = True
				End If
				If Not iProperties.Value("Custom", "OCCURRENCECOUNT") = Occs.Count Then
					SaveRequired = True
				End If
					iProperties.Value("Custom", "PARAMETERCOUNT") = oParams.Count
					SaveRequired = True
				End If
				If Not iProperties.Value("Custom","CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count Then
					iProperties.Value("Custom", "CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count
					SaveRequired = True
				End If
				End If
			Catch
				Exit Sub
			End Try
		End If
	End Try
End Sub
Message 4 of 14
j.romo
Thanks Guys thats exactly what i needed....
Kudos for both
Message 5 of 14
RoyWickrama_RWEI
Hi Chandra.Shekar;
In the process of scanning all occurrences,  I am currently interested in retrieving the parent child relationship of all the documents is an assembly. For example, it will have a name Parent1_p2300 for part p2300  (at 1st time occurence detected). If p2300 exists as a chiled in another assembly then variable Parent2_p2300. Parent3_p2300, Parent4_p2300 etcwill be created as required.
Could you provide me with a clue to retrieve this information.
I will provide you with a sample code to better illustrate my need.
Autoesk Inventor Professional 2019
Vault Professional 2019
Message 6 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Can you please provide sample assembly to illustrate parent - child relationship? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 14
RoyWickrama_RWEI
Thanks for the reply. I am not able to get around with my need. Finally, posted in the forum help.
https://forums.autodesk.com/t5/forums/postpage/choose-node/true/interaction-style/forum?interaction_...
Please try to help.
Thanks.
Message 8 of 14
RoyWickrama_RWEI
Hi Chandra;
Can we assign this quantity to the custom property, QTYT (for quantity Total)
Thanks.
Message 9 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Yes, you can assign total quantity to any custom property.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 14
RoyWickrama_RWEI
Could you provide me with the lines of code, please.
Message 11 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Try below iLogic code.
Sub Main()
	Dim cnt As Integer
	cnt = 0
        If oOcc.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then
			cnt = cnt + 1
		End If
    Next
	Dim propertyName As String = "TotalQuantity"
	Dim propertyValue As String = cnt.ToString
	customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
	Try
		prop = customPropertySet.Item(propertyName)
	Catch
	' Assume error means not found
		customPropertySet.Add("", propertyName)
	End Try
	iProperties.Value("Custom", propertyName) = propertyValue
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 12 of 14
RoyWickrama_RWEI
Thanks a lot.
Great help.
Message 13 of 14
RoyWickrama_RWEI
Hi Chandra;
It does not go the occurrences: creates TotalQuantity in the main assembly.
Could you take a look at. Thanks.
Message 14 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Try below changes.
For Each oOcc In oAsmdef.Ocuurences
			cnt = cnt + 1
		End If
    Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
