01:44 PM
so I'm trying to write an iLogic rule that fills out a nice list of the different sizes a part can be produced in in an Excel file, but I'm having some issues getting the Case statement to run properly with the different ranges of values. I get an error that says' XML Literal cannot appear here unless it is enclosed in parentheses'. here is my lines of code, what am I doing wrong here?
SyntaxEditor Code Snippet
GoExcel.Open("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet1") MessageBox.Show(SheetMetal.FlatExtentsArea, "FlatArea") Select Case Parameter("Table_Length") Case >= 12 And < 24 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B2") = SheetMetal.FlatExtentsArea Case >=24 And <36 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B3") = SheetMetal.FlatExtentsArea Case >=36 And <48 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B4") = SheetMetal.FlatExtentsArea Case >=48 And <60 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B5") = SheetMetal.FlatExtentsArea Case >=60 And <72 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B6") = SheetMetal.FlatExtentsArea Case >=72 And <84 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B7") = SheetMetal.FlatExtentsArea Case >=84 And <96 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B8") = SheetMetal.FlatExtentsArea Case >=96 And <108 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B9") = SheetMetal.FlatExtentsArea Case >=108 And <120 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B10") = SheetMetal.FlatExtentsArea Case >=120 And <132 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B11") = SheetMetal.FlatExtentsArea Case >=132 And <144 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B12") = SheetMetal.FlatExtentsArea Case 144 GoExcel.CellValue("Catalog Sheet - Dbl Roll Table 1.xlsx", "Sheet3", "B13") = SheetMetal.FlatExtentsArea End Select GoExcel.Save GoExcel.Close MessageBox.Show("FlatArea Updated", "Notice:")
