ilogic - copy drawing iproperty to model iproperty
Message 1 of 16
Hello!
I currently work in a company that has uses an automatic file numbering system for ipt and iam files. The idw file names are picked from the project's Master document register. In other words, the models get a random number / name, while the idw's are predined. This means that there's NO link what so ever between the model file name and the idw file name.
Now i want to create an ilogic rule that simply copies the idw's file name to a custom iproperty in the model.
I would like to do this, so I can find out (without opening vault) which idw is linked to a specific model.
Does anyone know how to do this?
I made this rule, which only works for models with the same name, doesn't it?
SyntaxEditor Code Snippet
'copy idw drawing number to ipt custom iproperties'Exit rule If no Part or Assembly Is in the drawing yet
If (ThisDrawing.ModelDocument Is Nothing) Then Return
'get the file name of the doc the drawing points to
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
'read the values from the iProperties in the part file'then apply to the iProperties with the same name in the drawing file
iProperties.Value(modelName,"Custom", "Drawing Number")=iProperties.Value("Project", "Part Number")
PS. I already created to custom iproperty in the model, to avoid any problems there.
thank you in advance!
Replies (15)
Message 2 of 16
bradeneuropeArthur
You better use the Vault API to achieve this.
Because:
  • What If the file is renamed in the vault
  • What If the file is moved in the vault
I can learn you haw to do this without adding any property to the documents......
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 16
waynehelley
I'm curious (mainly because I have never personally touched the Vault API) as to what you are suggesting here.
Is it fairly straight forward to retrieve information from Vault by adding reference to the Vault dll to an iLogic rule or NET addin?  I've always been too scared to try in case I bring a server down.
Do you have any examples?
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Message 4 of 16
bradeneuropeArthur
Are you familiar with creating add ins for inventor using VB.net?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 16
waynehelley
Yes I am.  What I'm curious about is how easy it is to use the Vault object library and how easy it is to connect to a Vault server.
Wayne Helley
Visual Studio 2022
Message 6 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
I just cross verified that below iLogic code works for different model name and drawing file name. Through Vault API, may be possible to retrieve model name associated with drawing and visa versa.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 16
bradeneuropeArthur
Hi @chandra.shekar.g
There are better solutions for this without properties.
Because Vault is used this method is not the best way.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@bradeneuropeArthur,
Yes! There might be better solutions.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 16
bradeneuropeArthur
@chandra.shekar.g
Our intention is the same I think.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 16
Hi Bradeneurope,
I don't really see the issue regarding the renaming or file moving comment. As long as the rule runs (i.e. every time the drawing gets saved) the new iproperty gets updated.
That said, I am interested in your solution (vault API). Do you have some examples or something you can share?
L
Message 11 of 16
bradeneuropeArthur
Yes.
Wil come back soon
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 16
bradeneuropeArthur
I could try to explain my arguments, but this is not related to the topic I think.
Yes I have example codes.
I use these methods a lot, because of the arguments above.
I am not on my desk right now so the examples will follow soon.
If you could already post an inventor add in as text, I can add my code to it. This is the easiest way I think.
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 16
bradeneuropeArthur
@Anonymous
Are you also familiar with vb.net and Add-ins?
Than please:
01-24-2018 07:43 PM in reply to: Boijens
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 16
bradeneuropeArthur
Hi'
I am ready to edit the code for you, but:
Than please:
Hi I have read your post again and if you really want to do it like you wrote then my option is not possible:
I think my option, Reading it from Vault is still the better way.
I am waiting for your respond.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 16
Hi again,
Even though I am really interested in it, I am unfortunately not very accustomed to using vb.net.
I am well aware I can find out through vault which drawing is attached to a part/assembly. The only thing I am trying to achieve is less mouse clicking. If I'ld have an iproperty showing the drawing number, I wouldn't have go in vault to find out.
Anyway thanks.
Message 16 of 16
bradeneuropeArthur
What do you want to achieve:
For example:
  • A button which will prompt or showing you the related drawing reference in vault (Vault Path's)?
  • A button which will prompt or showing you the related parts and assemblies reference in vault (Vault Path's)?
think this would be the simplest way!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
