iLogic Collapsible Code Disappears
kboucher
kboucher
Community Visitor
Community Visitor
I am having an issue with my Collapsible Code.  I put the quote mark (') and open bracket ([) in a line above my code and then put the closing bracket (]) in a line below my code.  I save my code and close it, but when I open the code again there is no collapsible code.  Just quote marks and brackets.  This happens no matter what.  If I change anything in the code the collapsible code comes back and works correctly.  Is there anyway I can keep the code working properly once I open it?
Thanks!
bradeneuropeArthur
Could you upload an example?
Or make some screenshots of what you mean.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
philip1009
Which Inventor version are you using?  I had this glitch with Inventor 2018.3 and persisted until the latest update in 2019 which returned the functionality of the collapsible brackets back to normal as far as I can tell.  And just like you said the bracket functionality didn't return until something in the code was changed, I just went to the beginning and added then deleted a blank line.
