Excel VBA to export a value from a cell to iProperties?
fabianrebora
fabianrebora
I need to export the existing values in the cells (example columan C) to the properties of the path files in column H.
If someone could help me, I will be very grateful
bradeneuropeArthur
You can use apprentice for this...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
fabianrebora
Sorry, I Can't understand your answer
Apprentice is basically a lightweight backdoor for inventor.  See this article for more details.
http://modthemachine.typepad.com/my_weblog/2010/03/iproperties-without-inventor-apprentice.html
This should get you on the right path.
fabianrebora
Thanks for putting me on the right path.
After some attempts, I did it
Public Sub Cargardatos()
' Declare a variable for Apprentice.
Dim invApprentice As New ApprenticeServerComponent
Dim r As Integer
r = 1
Line1:
' Open a document using Apprentice.
Dim invDoc As ApprenticeServerDocument
Set invDoc = invApprentice.Open(ActiveWorkbook.ActiveSheet.Cells(r + 1, 17))
Dim InvDocISI As PropertySet
Set InvDocISI = invDoc.PropertySets.Item("Inventor Summary Information")
Dim InvDocDTP As PropertySet
Set InvDocDTP = invDoc.PropertySets.Item("Design Tracking Properties")
Dim InvDocIDSI As PropertySet
Set InvDocIDSI = invDoc.PropertySets.Item("Inventor Document Summary Information")
' Edit the values of a couple of properties.
InvDocISI.Item("Revision Number").Value = ActiveWorkbook.ActiveSheet.Cells(r + 1, 2) ' revision
InvDocDTP.Item("Stock Number").Value = ActiveWorkbook.ActiveSheet.Cells(r + 1, 3) 'bas
InvDocIDSI.Item("Manager").Value = ActiveWorkbook.ActiveSheet.Cells(r + 1, 4) ' activo
InvDocIDSI.Item("Company").Value = ActiveWorkbook.ActiveSheet.Cells(r + 1, 5) ' clase de proveedor
InvDocISI.Item("Subject").Value = ActiveWorkbook.ActiveSheet.Cells(r + 1, 6) 'tipo
InvDocISI.Item("Title").Value = ActiveWorkbook.ActiveSheet.Cells(r + 1, 7) 'linea
InvDocIDSI.Item("Category").Value = ActiveWorkbook.ActiveSheet.Cells(r + 1, 8) 'equipo maquina
InvDocISI.Item("Keywords").Value = ActiveWorkbook.ActiveSheet.Cells(r + 1, 9) 'subconjunto
InvDocISI.Item("Comments").Value = ActiveWorkbook.ActiveSheet.Cells(r + 1, 10) ' descripcion
' Save the changes.
invDoc.PropertySets.FlushToFile
' Close the document and release all references.
Set invDoc = Nothing
invApprentice.Close
Set invApprentice = Nothing
r = r + 1
If Not IsEmpty(ActiveWorkbook.ActiveSheet.Cells(r + 1, 17)) Then GoTo Line1:
MsgBox "Terminado"
End Sub
