iLogic Code to speed up Updated Titleblock
brianmD486F
brianmD486F
Hi All!
So my current job can sometimes have 20-30 pages on my IDW and lot of times im going into my titleblock to edit our parts callout/finishes. Well after doing so you update that first page then have to spam okay for all the other pages to update. Is there a code out there that can run after the first update to just update all current sheets in the project?
Thanks!
bradeneuropeArthur
Is it one idw with multisheets?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
brianmD486F
Correct, 1 IDW with multiple sheets. I never know how many total I'll have, but easy enough if I have to go in and adjust numbers to make something work. Just gets tedious when the IDW has 40+ pages and I have to sit there to click okay over and over.
bradeneuropeArthur
Dim a As Inventor.DrawingDocument = ThisDrawing.Document
Dim b As Inventor.Sheet
For Each b In a.Sheets
b.Update
Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
brianmD486F
Perfect! Thank you sooooo much
