iLogic code for Hinge hole command for Inventor
I want iLogic code for Hinge hole command for Inventor
Drill the Hinge hole into the side of cabinate at door front
bradeneuropeArthur
Could you be more specific?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Code behaves as drills at center of the sheet metal
I want Drill on the side of cabinate at door.
Dim oSheetMetalDoc As PartDocument
oSheetMetalDoc = ThisApplication.ActiveEditDocument
' a reference to the component definition.
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oSheetMetalDoc.ComponentDefinition
' a reference to the sheet metal features collection.
Dim oSheetMetalFeatures As SheetMetalFeatures
oSheetMetalFeatures = oCompDef.Features
Dim oFace As Face
'Keep Selecting Faces, Hit Esc to finish
Do
    oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select a face")
    If Not oFace Is Nothing Then
        Exit Do
Loop While Not oFace Is Nothing
' Get the outer loop of the face.
Dim outerLoop As EdgeLoop
For Each outerLoop In oFace.EdgeLoops
    If outerLoop.IsOuterEdgeLoop Then
        Exit For
Next
' Create a workpoint at the edge mid-point
Dim oWorkPoint As WorkPoint
oWorkPoint = oCompDef.WorkPoints.AddAtCentroid(outerLoop)
Dim oPointPlacement As PointHolePlacementDefinition
oPointPlacement = oCompDef.Features.HoleFeatures.CreatePointPlacementDefinition(oWorkPoint,oFace)
' Create the hole feature, 0.5 cm dia
Call oCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent( _
                        oPointPlacement, 0.5, kPositiveExtentDirection)
'turn off workpoint
oWorkPoint.Visible = False
