Inventor 2016: Border Zones disappear when adding border using iLogic
So this issue has been going on for some time and I am unable to find  a solution. The "Activesheet.Borer" command has known issues with turning off zone markers.  Next, I tried codes that is supposed to simulate clicking the Insert Border button. This code worked ok for some time but now it keeps giving me the "Object variable or With block variable not set" error. The code runs up to the point of deleting the old border then errors out. Attached are both sets of codes and the .dwg file.
I could really use some help figuring out how to add borders with zones in Inventor 2016. My new templates are on hold due to this issue.
Thank you.
JelteDeJong
this iLogic rule will change the border and title block. i did test it in the dwg you attached. i did attach your changed dwg file.
Dim borderTypes As String() = {"KAssembly", "KGang Assembly", "KGang Part", "KPart"}
Dim selectedBorderName As String
selectedBorderName = InputListBox("SELECT A BORDER TYPE", borderTypes, borderName, Title:="BORDER NAME", ListName:="List")
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
For Each border As BorderDefinition In doc.BorderDefinitions
    If (border.Name.Equals(selectedBorderName, StringComparison.CurrentCultureIgnoreCase)) Then
        doc.ActiveSheet.Border.Delete()
        doc.ActiveSheet.AddBorder(border)
Next
Dim selectedTitleBlockName As String = ""
Select Case selectedBorderName
    Case "KAssembly"
        selectedTitleBlockName = "Kinze Assembly"
    Case "KGang Assembly"
        selectedTitleBlockName = "Kinze Gang Assembly"
    Case "KGang Part"
        selectedTitleBlockName = "Kinze Gang"
    Case "KPart"
        selectedTitleBlockName = "Kinze Part"
End Select
For Each titleblock As TitleBlockDefinition In doc.TitleBlockDefinitions
    If (titleblock.Name.Equals(selectedTitleBlockName, StringComparison.CurrentCultureIgnoreCase)) Then
        doc.ActiveSheet.TitleBlock.Delete()
        doc.ActiveSheet.AddTitleBlock(titleblock)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you very much for all your help with these codes.
The original problem, however, still exists in Inventor 2016. Border Zone markers disappear!
Raj Thapa
JelteDeJong
Hi, on my pc i get the border zones  but if i read the following posts then ther seems to be some bug.
Link1 Link2 Link3
It seems that you need to expand the border node in your browser befor you insert it. With those post i alterd the code i posted before but because i dont seem to have this bug i cant test it for you. there for i can only hope that this works. any way let me know.
Public Sub Main()
	Dim bp = ThisApplication.ActiveDocument.BrowserPanes("DlHierarchy")
			Dim borderNode As BrowserNode = FindBorderNode(border.Name, bp.TopNode.BrowserNodes)
			borderNode.EnsureVisible()
	Next
		Case "KAssembly"
		Case "KGang Part"
		Case "KPart"
	End Select
	Next
End Sub
Function FindBorderNode(name As String, nodes As BrowserNodesEnumerator) As BrowserNode
    Dim foundNode As BrowserNode = Nothing
    For Each node In nodes
        If name = node.BrowserNodeDefinition.Label Then
            foundNode = node
            Exit For
        foundNode = FindBorderNode(name, node.BrowserNodes)
        If Not foundNode Is Nothing Then
            Exit For
    Next
    Return foundNode
End Function
Jelte de Jong
Thank you for your code.
When I run your code with the InputListBox command active
I get a Microsoft.NET Framework error. See image attached. After I click on Continue, the browser expands and input list box opens. When I select a border and apply, it changes the border but the zones are still missing.
If I comment out the InputListBox line, the Microsoft.NET error does not pop up.
I think I am going to give up on this code to change the border and just do this bit manually.
Thank you a million for all your help. I finally got it working. I found out that my problem was related to not having Service Pack 2 for Inventor 2016 not installed on my PC.
It is working wonderfully now and the zones are intact and appearing as they should.
Again, thank you very much for helping!
Raj
