iLogic class destructor
DonStauffer99
DonStauffer99
I created a Finalize method in one of my classes. I instantiate the class in a parameter change rule, so it seems like it should go out of scope after the rule finishes, but the method never executes. Do destructors even work in iLogic classes? Is Finalize the right method name? Thanks!
DonStauffer99
Example: I put this code into a rule, and when it runs, the last message box says than n_ is 3. It seems like it should be zero at that point. The messages in the Finalize method never display. It seems like one or the other of them should display 3 times. I have a bigger project, and classes that unload files in their destructor. Those destructors never ran until I put a Save (to disk) function in my code before the objects go out of scope. Then the destructors mostly started running. Why would it be inconsistent like that?
SyntaxEditor Code Snippet
ublic Class ThisRule
	Public Sub Main()
		Dim a As New Counted
		Dim b As New Counted
		MsgBox("creating a")
		a = Nothing
		MsgBox("a destroyed")
		f()
		MsgBox("f returned")
		b = Nothing
		MsgBox("b destroyed")
		MsgBox("n=" & Counted.n_.ToString())
	End Sub
	Public Sub f()
		Dim c As New Counted
	End Sub
End Class
Public Class Counted
	Public Shared n_ As Integer = 0
	Public Sub New()
		n_ = n_ + 1
	End Sub
	Public Sub Finalize()
		n_ = n_ - 1
		If n_ = 0 Then
			MsgBox("Destroyed!")
		Else
			MsgBox("Not Destroyed")
		End if
	End Sub
End Class
DonStauffer99
No speculation, even? Confirmation this happens? Additional information about when it does or doesn't happen, or workarounds?
AlexFielder
Hiya,
In my experience, in a "Try Catch Finally" scenario - the Finally always fires so you could use that instead?
DonStauffer99
That's an interesting idea. I did discover that Microsoft revised VB so it no longer has destructors! This may help work around. Thanks .for the suggestion.
