Copy Model iProperty Settings with iLogic
tomas_wiklund
Message 1 of 12
tomas_wiklund
Hi!
I try to find a way to select properties to be "Copied iProperties" in a drawing.
I know how to do it in [Document Setting/Drawing/Copy Model iProperty Settings...].
Is there any way to do this with iLogic?
/Tomas
Replies (11)
Message 2 of 12
dgreatice
You get bad luck for this, you only can setting Additional Custom Model iProperties Source.
https://forums.autodesk.com/t5/inventor-customization/externally-modify-additional-custom-model-ipro...
BUT, you cant select that properties list to be in "Copied iProperties". because there are no API to access to this Tool.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 3 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@tomas_wiklund,
Try below iLogic code to copy Model iProperty to Drawing Document.
Dim oPropList As ArrayList = New ArrayList()
oPropList.Add("AUTHOR")
oPropList.Add("AUTHORITY")
oPropList.Add("CATEGORY")
oPropList.Add("CHECKED BY")
oPropList.Add("CHECKED DATE")
oPropList.Add("COMMENTS")
oPropList.Add("COMPANY")
oPropList.Add("COST CENTER")
oPropList.Add("CREATION DATE")
oPropList.Add("DESCRIPTION")
oPropList.Add("DESIGN STATE")
oPropList.Add("DESIGNER")
oPropList.Add("ENGR APPROVAL DATE")
oPropList.Add("ENGR APPROVED BY")
oPropList.Add("ENGINEER")
oPropList.Add("ESTIMATED COST")
oPropList.Add("KEYWORDS")
oPropList.Add("MANAGER")
oPropList.Add("MFG APPROVED BY")
oPropList.Add("MFG APPROVED DATE")
oPropList.Add("PART NUMBER")
oPropList.Add("PROJECT")
oPropList.Add("REVISION NUMBER")
oPropList.Add("STATUS")
oPropList.Add("STOCK NUMBER")
oPropList.Add("SUBJECT")
oPropList.Add("TITLE")
oPropList.Add("VENDOR")
oPropList.Add("WEBLINK")
sel_iProperty = InputListBox("CHOOSE iPROPERTY FROM ABOVE LIST", oPropList, oPropList.Item(0), "iPROPERTY SELECTION", "LIST OF iPROPERTY")
oRefDoc = ThisDrawing.ModelDocument
Dim oPropValue As String
Select Case sel_iProperty
Case "AUTHOR"
	oPropValue = oRefDoc.PropertySets("Summary Information").Item("Author").value
	iProperties.Value("Summary", "Author") = oPropValue
	MessageBox.Show(sel_iProperty + " iProperty updated successfully with value : " + oPropValue, "iProperty")
Case "AUTHORITY"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Authority").value
	iProperties.Value("Project", "Authority") = oPropValue
Case "CATEGORY"
	oPropValue = oRefDoc.PropertySets("Document Summary Information").Item("Category").value
	iProperties.Value("Summary", "Category") = oPropValue
Case "CHECKED BY"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Checked By").value
	iProperties.Value("Project", "Checked By") = oPropValue
Case "CHECKED DATE"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Date Checked").value
	iProperties.Value("Project", "Date Checked") = oPropValue
Case "COMMENTS"
	oPropValue = oRefDoc.PropertySets("Summary Information").Item("Comments").value
	iProperties.Value("Summary", "Comments") = oPropValue
Case "COMPANY"
	oPropValue = oRefDoc.PropertySets("Document Summary Information").Item("Company").value
	iProperties.Value("Summary", "Company") = oPropValue
Case "COST CENTER"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Cost Center").value
	iProperties.Value("Project", "Cost Center") = oPropValue
Case "CREATION DATE"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Creation Time").value
	iProperties.Value("Project", "Creation Time") = oPropValue
Case "DESCRIPTION"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Description").value
	iProperties.Value("Project", "Description") = oPropValue
Case "DESIGN STATE"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Design Status").value
	iProperties.Value("Project", "Design Status") = oPropValue
Case "DESIGNER"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Designer").value
	iProperties.Value("Project", "Designer") = oPropValue
Case "ENGR APPROVAL DATE"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Engr Date Approved").value
	iProperties.Value("Project", "Engr Date Approved") = oPropValue
Case "ENGR APPROVED BY"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Engr Approved By").value
	iProperties.Value("Project", "Engr Approved By") = oPropValue
Case "ENGINEER"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Engineer").value
	iProperties.Value("Project", "Engineer") = oPropValue
Case "ESTIMATED COST"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Cost").value
	iProperties.Value("Project", "Cost") = oPropValue
Case "KEYWORDS"
	oPropValue = oRefDoc.PropertySets("Summary Information").Item("Keywords").value
	iProperties.Value("Summary", "Keywords") = oPropValue
Case "MANAGER"
	oPropValue = oRefDoc.PropertySets("Document Summary Information").Item("Manager").value
	iProperties.Value("Summary", "Manager") = oPropValue
Case "MFG APPROVED BY"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Mfg Approved By").value
	iProperties.Value("Project", "Mfg Approved By") = oPropValue
Case "MFG APPROVED DATE"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Mfg Date Approved").value
	iProperties.Value("Project", "Mfg Date Approved") = oPropValue
Case "PART NUMBER"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Part Number").value
	iProperties.Value("Project", "Part Number") = oPropValue
Case "PROJECT"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Project").value
	iProperties.Value("Project", "Project") = oPropValue
Case "REVISION NUMBER"
	oPropValue = oRefDoc.PropertySets("Summary Information").Item("Revision Number").value
	iProperties.Value("Summary", "Revision Number") = oPropValue
Case "STATUS"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("User Status").value
	iProperties.Value("Project", "User Status") = oPropValue
Case "STOCK NUMBER"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Stock Number").value
	iProperties.Value("Project", "Stock Number") = oPropValue
Case "SUBJECT"
	oPropValue = oRefDoc.PropertySets("Summary Information").Item("Subject").value
	iProperties.Value("Summary", "Subject") = oPropValue
Case "TITLE"
	oPropValue = oRefDoc.PropertySets("Summary Information").Item("Title").value
	iProperties.Value("Summary", "Title") = oPropValue
Case "VENDOR"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Vendor").value
	iProperties.Value("Project", "Vendor") = oPropValue
Case "WEBLINK"
	oPropValue = oRefDoc.PropertySets("Design Tracking Properties").Item("Catalog Web Link").value
	iProperties.Value("Project", "Catalog Web Link") = oPropValue
End Select
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 12
dgreatice
This method is to Copy iProperties Model and Save in iProperties Drawing.
how to copy custom iProperties Model to Custom iProperties Drawing?
Message 5 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@dgreatice,
Try below iLogic code to copy custom iProperty from Model to drawing document.
oPropValue = oRefDoc.PropertySets("User Defined Properties").Item("Sample").value
iProperties.Value("Custom", "Sample") = oPropValue
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 12
dgreatice
I think you must use iteration:
dim oPropsets as PropertySets
oProptSets = oDoc.PropertySets.Item("User Defined Properties")
dim oProp as Property
For Each oProp in oPropSets
      'Next Code to store to object collection
      'PropList.Add oProp.Name
next
Message 7 of 12
tomas_wiklund
I did a quick test with this:
SyntaxEditor Code Snippet
oPropValue = oRefDoc.PropertySets("Summary Information").Item("Author").Value
'And for Custom Properties oPropValue = oRefDoc.PropertySets("Inventor User Defined Properties").Item("Monitor").Value iProperties.Value("Custom", "Monitor") = oPropValue
It seems to work fine. I'll be building a permanent solution later this week (perhaps).
Thanks Ihsan!
Message 8 of 12
This is fantastic!
Short simple solution, I had been looking through various posts, but this is bang on.
Sam
Message 9 of 12
matteo_pallaroni
Hi I'm currently testing it on Inventor 2021.3 and it returns:
(Exception HRESULT: 0x80004005 (E_FAIL))
the only change applied is:
oPropValue = oRefDoc.PropertySets("Inventor Document Summary Information").Item("Subject").Value
iProperties.Value("Summery", "Subject") = oPropValue
 i tried also a step by step declaration, like:
'Ok here
Dim oPropsets As PropertySets
oPropsets = oRefDoc.PropertySets
'Ok here
Dim oPropset As PropertySet
oPropset = oPropsets.Item("Inventor Document Summary Information")
Dim oPropValue As [Property] 'Some unexpected brackets...????
TestValue = oPropset.Item("Subject") 'not ok
'Alternative, still not working
TestValue = oRefDoc.PropertySets("Inventor Document Summary Information").Item("Subject").Value
no idea...
Message 10 of 12
steveh3
@matteo_pallaroni
Hello Matteo...
Attempting to use same logic. Getting same error [Exception HRESULT: 0x80004005 (E_FAIL)]
Did you find a resolution?
Best,
Steve Hilvers
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Message 11 of 12
WCrihfield
I don't know the scope of the task you are wanting to achieve (how many iProperties you want to copy from model document to drawing document), so I created an all inclusive iLogic rule that will attempt to copy ALL iProperties from the model to the drawing.  I had to include some Try...Catch blocks in there, because some iProperties are 'ReadOnly', and in odd cases, some special/custom PropertySets/Properties may simply not want to copy over.  I also included the use of a Transaction, to lump all this into one item in the Undo list, so it can easily be undo in one click, if needed.  This may be a bit overkill, but here it is anyways.
Dim oDrawing As DrawingDocument = ThisDrawing.Document
Dim oModel As Inventor.Document = ThisDrawing.ModelDocument
If IsNothing(oModel) Then Exit Sub
'lump all following actions into one item in the Undo List
oTrans = ThisApplication.TransactionManager.StartTransaction(oDrawing, "Copy All iProperties")
For Each oModelPropSet As PropertySet In oModel.PropertySets
	Dim oDrawingPropSet As PropertySet = Nothing
	If Not oDrawing.PropertySets.PropertySetExists(oModelPropSet.Name, oDrawingPropSet) Then
		Try
			oDrawingPropSet = oDrawing.PropertySets.Add(oModelPropSet.Name, oModelPropSet.InternalName)
		Catch
			Continue For 'PropertySet can't be copied, skip to next PropertySet
		End Try
	If oModelPropSet.Count = 0 Then Continue For
	For Each oModelProp As Inventor.Property In oModelPropSet
		'if Custom PropertySet, property might not exist yet, so check
		Dim oDrawingPropExists As Boolean = False
		If oDrawingPropSet.Count = 0 Then GoTo TryCreateProp
		For Each oDrawingProp As Inventor.Property In oDrawingPropSet
			If oDrawingProp.Name = oModelProp.Name Then
				oDrawingPropExists = True
				Try 'some iProperties are 'ReadOnly'
					oDrawingProp.Value = oModelProp.Value
					Exit For 'found so stop iterating
				Catch
				End Try
		Next 'oDrawingProp
		TryCreateProp :
		If Not oDrawingPropExists Then
			Try 'Drawing iProperty did not exist, so try to create it
				oNewDrawingProp = oDrawingPropSet.Add(oModelProp.Value, oModelProp.Name, oModelProp.PropId)
			Catch
			End Try
	Next 'oModelProp
Next 'oModelPropSet
oDrawing.Update2(True)
oTrans.End
MsgBox("Copying iProperties Task has finished.", vbInformation, "")
I also have a contribution post about just copying only all custom iProperties from the model to the drawing.  I use that one all the time.  Here is a link to that one, in case you might find it useful.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Message 12 of 12
steveh3
@WCrihfield ....
Thanks I will take a look and see how/if I can incorporate it.
Best,
Steve Hilvers
